Has anyone used MOOG replacement endlinks and sway bar bushings?
Looks to be a great product but seems to have a fair amount of bad rviews in terms of wearing out fast.
are the moog a poly replacement or just a standard rubber replacement?
I ran energy suspension parts on mine before I switched to the addco front bar and had good luck with them.
The Moog parts are a thermoplastic. Not much info on it really. Apparently between rubber and poly. Supposed to be hard like poly but absorb small vibes and noises like rubber does. They dont need greasing and doesn't make noise like poly does.
But there are alot of negative out there on them so im rather hesitant. May just go the same route you did with endlinks and custom bushings.
