I have seen a few how to's for the rear disk conversion but I felt they were not really doable by some people. So, here is mine where i do not alter anything and just do direct bolt on for everything. Also, this is my first how to so go easy on me.
what you'll need.
Mr. Quick's Saturn/Neon bracket
Calipers
brake line
e-brake bracket
Caliper bracket
Brake hardware kit (slider pins, dust boots and retainers)
and what makes mine different form the others, the parking brake cable form a 95-02 cavy.
You will only need a basic set of tools that most people have.
Here we go,
First, jack up the car and remove the rear wheels. Taking off the drums was the hardest part for me because of the rust between the axle and drums, basically just work at it until it pops off.
After taking the drums off i took the shoes off just to make it easier to get the E-brake cable off.
Next unbolt the wheel bearing and unscrew the brake line going to the wheel cylinder.
I found a little friend while i was in there. :-)
Then, install the bracket behind the axle.
After that I replaced the parking brake cable with the ones i got off a 96 cavy
Old one
New one
The difference
The only cables you really need to change are the two back ones because the one running up to the hand brake lever is the same length at the others. taking them off wasn't to hard, I just used needle nose pliers to take them off. The place they are mounted on the frame just uses clips to hold them in and the area they connect to the longer cable is easy to take apart by just squeezing them in to take them off.
view of where they are connected together and to the frame.
disconnected
Personally I found this much much easier than relocating the parking brake bracket.
After installing the other cable install the rotor and caliper mounting bracket.
then install the new hardware onto the bracket.
Next, connect the parking brake cable to the caliper.
Then install the pads and place the caliper on using the new bolts that came with the hardware kit.
The brake lines form the cavy match the lines that are already on the Saturn caliper so I just screwed them together. (I suggest replacing with steel braided lines, I will be eventually).
Everything hooked up.
Last thing you have to do it bleed your system and you should be set.
other side done.
And to finish it all up a couple before and after pics.
Hope this helps and hope it shows how much easier it is to replace the cables than to relocate the bracket. ( The main reasons I did not relocate the bracket is because: I didn't have access to all my tools to drill holes and stuff, and I am going to school for mechanical engineering where I am learning the application of forces and I really feel that if you move the bracket you are adding stress to the system that could cause issues later.)
This was a fun project and I encourage anyone interested to do the conversion.
So i guess the ebrake cables changed from 95-02 to 03-05 when the drum assembly changed to the larger drums and simple design?
AWESOME work man! If I were to do it that's exactly how I would go about it. WAY easier than changing the bracket.
What did this cost you in total?
"In Oldskool we trust"
Y3llowCav wrote:AWESOME work man! If I were to do it that's exactly how I would go about it. WAY easier than changing the bracket.
Total for everything was approximately $415. I saved up and it took a while to get everything but it was defiantly worth it. My brakes stop much better than before.
Ok, so where did the rotors come from? I see that the caliper and bracket came from a saturn but I'm under the impression that the saturn rotors were not 5x100. Are these rotors from a neon?
Yes the rotors are from a SRT4 neon.
Thats the nice thing about Mr.Quick brackets. Use all off the shelf parts and the neon rotor is larger.
Hows the stopping power compared to stock??
We just need a link to Mr quicks bracket for this to be a complete how to.
This is on my to do list this winter.
Sticky!
Also is you already have a 2001 cavy would the parking brake just fit?
Yes.. 95-2002 the parking brakes are all the same.
Philly D wrote:Yes the rotors are from a SRT4 neon.
Philly D wrote:^^
Thank you for answering. Philly D
Also here is a link to Mr. Quick's GP
http://www.j-body.org/forums/read.php?f=sales&i=40921&t=40921
Awsome,
Would you happen to have any part numbers?
Rear brake cable: Wagner BC138088. They're about $25 each anywhere that carries them.
As for the drums and calipers, just go to any part store and buy the following:
calipers from a 99 Saturn SC2
brake lines from the SC2 or DSMskyline's brake lines (recommended)
rotors from an 04 Neon (base or SRT work---the difference is SRT is 3mm thicker)
Those are the ones I used, although the year range is pretty wide.
Weird, I called my local parts dealer they had told me a 1999 has rear drums.
Maybe a candain thing?
Maybe a Canada thing?
shayne godding wrote:Weird, I called my local parts dealer they had told me a 1999 has rear drums.
It may depend on the trim, but any similar year S-series should have the same caliper.
Mr. Quick wrote:Rear brake cable: Wagner BC138088. They're about $25 each anywhere that carries them.
okay so do we buy two of the same Wagner style cables for the rear?
which is what im thinking is a yes.. and does the 3mm thicker make a difference?
(write what ever comment you want here)
