Can the twist beam rear suspension be boxed? - Suspension and Brake Forum
Friday, September 19, 2014 9:48 AM
Curious if this can be done. Looking for alternatives to a rear sway bar. Seems these are becoming harder to find and more expensive.
This is for a track only car, so no concerns about NVH etc...
Thanks in advance.
Re: Can the twist beam rear suspension be boxed?
Friday, September 19, 2014 11:40 AM
Maybe box like a 1-2 foot section in the middle? I think boxing the entire thing would be too much.
"In Oldskool we trust"
Saturday, September 20, 2014 8:44 AM
In theory it would work, but the triangle shape it would form will end up ripping all the welds off the plate on the bottom. Triangles don't like twisting. If you used a round tube it would work fine.
Saturday, September 20, 2014 9:26 AM
for 95 and up (3rd gen) see if you can find a Z24 in the junkyard. the rear beam has a anti sway bar welded into it.
dennis
Saturday, September 20, 2014 8:44 PM
You could drill the hole in the middle of the axle and weld a long rod in on both sides like the factory sway bar. People have done this.
Sunday, September 21, 2014 11:45 AM
OEM did this to the reaper, search for the rebuild on it and i think theres a couple of pics you can see of it. They don't show "how to" or any details, just says they did it.
Monday, September 22, 2014 11:44 AM
All great replies, thanks! Searching for that build now.
Saturday, October 11, 2014 11:25 AM
I did box the rear beam axle on my sedan and I also have a rear sway bar. It helps with twisting of the rear beam. I believe I used 1/4" thick plate and drilled 3 decent size holes in the middle.
XtremE2200CaV: The Build has Begun
http://www.cardomain.com/ride/3864109/2001-chevrolet-cavalier-sedan-4d
Saturday, October 11, 2014 11:44 AM
Wednesday, October 15, 2014 9:42 AM
That's awesome, thanks for the pics! I was finally able to find a rear sway, but I am still interested in doing this at some point (probably this winter). I am curious to see how the sway bar by itself impacts the handling and go from there.
Wednesday, October 15, 2014 11:19 AM
I plated mine side to side and added 1-1/4 tubing for more support, prob. overkill but i have air ride. stopped it from twisting so much, ill get a pic
