i was wondering if there are full kits for our cars made by prothane or anyone else? also does anyone make solid mounts for the ECOTEC engine?
There isn't really a "kit" as there aren't many suspension bushings to replace.
Rksport and turbotech racing both offer motor mounts for the ecotec.
There is a control arm kit.
Then tranny mounts, which should be considered a kit.
Then you can buy replacement upper and lower motor mounts.
then of course you can always buy the poly sway bar end link bushings....
there have been runs of poly rear trailing arm bushings from LZM or delrin rear bushings from OEM. however, both sets are scarce and pretty hard to find these days.
if you look up LFU engineering on facebook they make an aluminum replacement steering rack bushing as well.
RIP silver car. You will be missed.
prothane makes bushing kit for the lower a arms upper and lower engine mount and manual trans mount bushings. but mine is 2.2 95-99 style
I would like to get my hands on some rear trailing arm bushings if possible?
thanks I found LFU and bought some stuff!!
who or what is LZM? or OEM?
lzm is level zero motorsports. Oem was overkill engineering motorsports. Oem is no longer making parts.
I'd avoid lzm if you're looking for the torsion beam bushings. Mine failed shortly after install.
