Hey guys,
I talked with Jim (at Air Lift) again on Friday. A little bit about the clunking and some about the bash
Anyways, here is another possible fix for the clunking issue, if you are having it.
-take the front struts off the car
-set the dampening level all the way to the left (softest)
-cycle the strut 3-4 times
The reason for this is because during shipping when the struts are on their sides air bubbles are created inside the strut.
He told me this *should* hopefully cure your issue if you're having it.
<br>
www.TaillightTinting.com #1 SOURCE FOR VHT NITE SHADES
www.aPlusPerformance.com BACK ONLINE SOMETIME SOON!
PHONE 763-682-9945
Cool deal.
Makes sence because I think mine have already settled out there problems. Im not getting the clunking anymore.
I have put alot of miles on my car sence ive had them. But I will prolly go ahaead and take them off anyway just to do it. And SO I can cut out more of my front fenders. <br>
I am all that is man
Sounds like a viable explenation. Will do. <br>
I don't know, but I'll try it.
Pat <br>
<img src="http://mywebpages.comcast.net/pahtcub/sample.jpg">
Non-member of Team Unofficial
"No club, no rules, no leaders,no sponsors, NO Bull$hit"
That is close, but leave them on the car, and turn them all the way the the hardest setting. Cycle them through a few times.
Remember when I said that we could not get our car to reproduce that sound.... we do this before every install. The problem is that if they sat on their side for extended periods of time (on the shelf or shipping) air bubbles can set in causing the strut to rattle. Easy fix for a lot of the problems.
Since I have been gone, I have lost track with who is where on this rattle thing. I am opening the door again! If you are still having the problems, E-mail me! I don't want anyone to settle for a sub par set up. E-mail me either way, If you are having a problem, or if everything is fine. I want to keep informed
Thanks again for all of your patients.
Jim@Airlift
JimBigford@airliftcompany.com
1-800-248-0892 ext 252
I will be sure to get to this once it stops raining around here.
damn rain always hindering my progress. <br>
Did this fix anyone's problem? Is anyone else still having the clunking?? Did anyone do anything imparticular to fix it? I've sent my struts back and they're looking at them now, just seeing who else was still having a problem or who fixed theirs.
Pat <br>
I have Phatcubs struts here now, and one other pair of fronts. We still have not been able to reproduce the sounds. There are a LOT of variables though. It could be the strut, the mounting, it could be on a car with 297,000 miles ....ect. The stock cavalier that we tried them on is a 01 4 door with about 60K on her.
I can only help out the people that contact me! I have posted before, if you have a problem....call me! I am here WAY more than I should be
Here is my number again, 1-800-248-0892 ext 252. This is the same strut that is on our Neon, Grand Am, Grand Prix, and a few others. I am just not haveing that problem. I know we will get to the bottom of it.
Once again, give me a call or e-mail me if you are having this problem. I will find an answer! I don't want ANYONE mad at me when I show up at the bash!
Thanks Guys!
Jim@Airlift
JimBigford@Airliftcompany.com
so jim, when i finally get mine, do you recommend i do this or have you guys worked out the problem. thanks
infamous ford focus easystreet mixup....
Mine were on an 02 2door with under 30K on it. If they get this fixed I'm humping Jim at the bash.:-)
Pat
<br>
mine only make a popping noise when i raise the car up, while driving mine is quite! any ideas it almost sounds like a suction cup being pulled off of something? <br>
SEVENONESIX
check out my cardomain
http://members.cardomain.com/sevenonesixcav
PSSSSSSSSSSSSSST GOT AIR????
Yeah I had that too, ESB said it's cause the bag creates a vacume, but it sounds like plastic popping, not a good sound. Hopefully this'll fix it.
Pat <br>
Pahtcub wrote:Yeah I had that too, ESB said it's cause the bag creates a vacume, but it sounds like plastic popping, not a good sound. Hopefully this'll fix it.
Pat
OK that paticular sound made when lifting after being all the way down is in fact the bag breaking a suction from itself. Its just a thing bags do. its no problem at all. My neighbors truck does it also.
THe bottom portion of the frotn bags dont ahve a role plate. when the air lets out the bag rolls down on it self and seals just like a suction cup would. When you add air the bag lifts and breaks that seal makking the pooping sound.
Im not just guessing here eather yall. I ran my front lines into a T and used my home air compressor to slowwly lift the front while I was lieing in perfect position to the see the front bag as car slowely lifted.
You can try yourself if you have a long cord on switchbox. But it may be too fast to notice.
Every now and then I'll lift car, but not enough to break that suction. THen out of noware it will pop up bit. Its no big deal really.
BUT!!!!!!!!!!! I still have that clanking sound coming from front when Im driving. I posative that it has got to be those upper mounts. Metal to metal is going to make noise. The rubber bushings may keep the strut from going up or down but they dont stop that shaft from going side to side in that little bit of space they have.
Ive been thinking of tring to use my 00 stock uppers. Anyone tried this? Im not sure is shaft size is the same or not. I'd like to check it out soon. <br>
Heres a pic of what I THINK may be the problem.
<img src="http://img45.exs.cx/img45/2125/Picture193.jpg" alt="Image Hosted by ImageShack.us" />
Now easystreet said this lorger hole is so that the strut will have some play from side to side twisting . Which im not arguing. I totaly understand that.
Im thinking maybe some kind of urethane ring inside would help.
Pahtcub------You have had your struts off car now after use. I have not yet.
Have you noticed any ware and tare on the shaft at the location that rest in the upper mount? <br>
Definately would have to AGREE with you on that. Common sense would tell youn that anytime you have metal to metal contact, you are going to have a 'noise' isssue.
im surprised i dont have any clunking. i do have two little dimples in my friggin hood from them though...that pissed me off. maybe its from the shaft lightly hitting your hood...just a thought...ive never heard it so i dont know how loud it is.
my car <br>
"Custom cars, custom problems."-me
mine work fine, i havent heard anything from the struts. I only get that popping noise when i raise my car up <br>
Might be the big hole but then why do some people dont have it?? I mean I can swerve back and forth like there's no tommorow and not have any problems, it's just over bumps, I noticed when I changed my mounts to the new ones Jim asked me to check that the two allen screws that kept the bag in place were loose, but I tightened them and it stil happened so I figured it wasn't that.
Pat <br>
There are different problems for different people. I don't think that all of them are strut related. I am sure some are. ESB is one smart cookie. He has hit on a lot of valid points. One that was left out though is "bump steer". If you do not get an alignment after you replace your struts, you could hear a lot of strange things.
C Cooper, I still only know of 4 people, now counting ESB, that have the problem. I have sold quite a few in the last few months. I believe that these are isolated problems. Good news though, it looks like your struts will leave Monday morning. By the way guys, this is a dealer problem, not ours
ESB, Phatcub, Give me a call today if you have time. I would like to have you guys talk to our engineers. They have some ideas, but no sense in "shooting in the dark"
Phatcub, if this thread dies soon....I may just take you up on your offer
Thanks again guys.
Jim@Airlift
Yes, jim and the guys at easystreet are not responsible for the mistake. but thats good news that they might be sent out monday, i might just get them after all. haha. ill go ahead and cycle them through before i put them on anyway. thanks
my struts clunk like crazy. It's almost as bad as when i had koni's and hp coilovers. I expected the EAI kit to be stock suspension quiet.
it sounds to me like the metal plate (upper mount) on the inside of the strut tower could be making the noise, just an opinion. did you guys wrench yours down tight? try putting a piece a rubber in between there. but then again why wouldnt mine do it <br>
SEVENONESIX
JIM BIGFORD wrote: ESB is one smart cookie.
I tell ya, If I had a Quarter for every time I heard that...............Well then Id have myself a cool 25 cents.
What are best times for me to call? Im guessing yall are on a mon-fri 9-5 kinda thing maybe? <br>
