Today I have begin the swap from a alero 2000 with rear disc brake
here the parts
The parts on the cav hehe
And my first problem the exhaust line hitting the cross member
Cool! Keep us up to date with the progress!
Keep me posted on how you bolt that sucker to the frame.... plus the spacers..
(I'm working on the same thing LOL)
...j
<a href="http://www.lenkorules.com/"><img src="http://s93165229.onlinehome.us/images/zm/sig/LRDCsig3.jpg"></a>
listening as well. It seems like everyone gets this far and that is the last time you hear from them. Its like they all fall from the face of the earth.
Jim
Thats because if you attempt this mod, the mod mob visits and disapears you...
If you havn't heard of the MOD Mob. It's a small unknown branch of GM and CARB. They took out the Turbosport, Technic, and a bunch of other good ideas from GM.
<img src="http://www.j-body.org/registry/americanred/deplysig.gif">
^^yea ive herd about them.....thats one crowd you dont want to mess with
i'm still doing mine, but it's just too damn cold to put it on so i'm building my engine instead. recently though i've trimmed an inch off of all of the arms, and it all measured out great. just need to get new rotors and pads and put it all on. that's another problem; i'm waiting for exploited racing to get a car out of the shop so i can do it there.
-nick-
<img src="http://registry.gmenthusiast.com/images/changeforabutton/100_0094_1.JPG">
Member of Wisc_Jbodies
Powered by *Exploited Racing*
Powered by Team Green
Am I on crack, or is that a rear drum setup??
<img src="http://boner.berettaspeed.com/cavysig.jpg">
no those are disks, its just hard to tell because of the rust LOL
I think he's talking about the pads on the top of the assembly
Yes it's disc.  Most cars have a rear disc/drum setup.. It's two small pads on the inside of the disc that are used for the E-break and then you have the disc and caliper that do the stopping.
listening to see if this gets finished.
-da chinchilla
<img src="http://registry.gmenthusiast.com/images/jiggamon/avatar15569_2.gif">
so whats up with this setup?  has anyone ever got it finished?
 Im assuming you dont have axcess to a welder?  If it was my car, there would be no way i would mount that ugly press bent peice of sheet metal under my car if i was doing a custom suspension install like that.  Id use a few pieces of  2" x 2"  1/8" wall box tubing and make a custom mount that would clear the exhaust, and bolt directly to the rear of the car without using a bunch of spacers to make it sit in there correctly
i think that the disk/drum setup is only used on rwd and 4wd vehicles. i don't think gm ever employed it on the fwd cars. cause i've changed a lot of rear axles on these cars and haven't seen it yet.
Nearly all GM vehicles w/ rear discs use the Disc/Drum setup... W-bodies, N-bodies, etc...
if the exhaust is in the way i would suggest just unbolt the catback until you have the irs done the go to a muffler shop and have them make a new catback for you. you can still use the muffler and exhaust tip, but you already found out the pipe wont work. i think with irs you can have the exhaust come right down the center of the car. which would cut down on bends and even use less pipe dropping a little bit of weight.  i wish i was getting irs
I think all Aleros came with rear discs... and Grand Am GT's as well. The base Grand Am's have drums.
Heh.. I have side exhaust... nothing in the way to interfere with this mod...
 except for the need for lowering springs and Koni's, of course...
...j
hmmm, very interesting. I was going to post on this topic just becuase i think the jbody suspension is the worst ive ever driven, but this post show up in a search...
listening...
2004 Cavalier, 2.2L Ecotec
1965 El Camino, 396 BBC, 14:1, 800 BHP
IRS?? Isn't that where you send your Federal Taxes in to?  LOL
®â€îñg666™
John Lenko wrote:Keep me posted on how you bolt that sucker to the frame.... plus the spacers..
...j
A few of us working on the same damn thing.....
More pics.......
SPD RCR Z -
'02 Z24  420whp
SLO GOAT  -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
