I am having an air suspension installed and have a question regarding alignment, do I need a camber kit?  I have one from Eibach here will that work if needed? What about the rear?
Thanks
our cars do not require camber kits, or any adjustment to camber
MeltdOwn350 aka cOdy wrote: or any adjustment to camber
WRONG!
<img src="http://mywebpages.comcast.net/pahtcub/sample.jpg">
you wont need a camber kit but you should go get it aligned once you got the kit on.  set it to a hieght you ride at and get it aligned.  its better than nothing.  theres no way to get it back exactly at the psi on each corner to drive every time (unless you dont play with the switches)  but it still helps
MeltdOwn350 aka cOdy wrote:our cars do not require camber kits, or any adjustment to camber
Thank you for speaking about what you dont know.
The air struts for our cars have elongated bolt holes for the spindle which are used for
CAMBER adjustment.
You cant just throw them in any old way like stock struts and be close to the proper setting.
I am all that is man
Pahtcub wrote:MeltdOwn350 aka cOdy wrote: or any adjustment to camber
WRONG!
i've been wrong before, i'll be wrong again. how much adjustment is needed then if i'm "WRONG!"?
i didn't see esb's post. the bolt holes makes sense, now i know.
thanks guys.
