does anyone have the dimensions for the front bracket for the baer brakes, l'm going to be using corvette calipers
l want to up grade my front brakes to 12'' and l'm using covette front calipers,
the baer front upgrade uses an adapter bracket for the calipers and l need to know the dimension so l can have a set cut and made for my z24
i dont think anyone has that, but i think you could maybe purchase it from baer.....
the front brakes don't have an adapter braket, they modify the steering knuckel I think, whatever the stock caliper mounts to, they use that, cut parts away so the caliper will fit properly and drill holes, same deal with the 13"s
Cherub (AZ) wrote:the front brakes don't have an adapter braket, they modify the steering knuckel I think, whatever the stock caliper mounts to, they use that, cut parts away so the caliper will fit properly and drill holes, same deal with the 13"s
They still use a bracket.  They just modify the knuckle to allow the bracket to sit flush against it and to remove the stock pad guides.
hey weasel do you have the meserments for the front backet
Sorry man.  No I don't.
I've got the 13" kit, not the 12", though I don't have the measurements for that either.  Never had reason to take any.
