Okay, i had arospeed coilovers on my Koni Reds...and i went to put Sportlines on the konis...and the sportlines mounted good on the front...but i cant get the sleeve off of the koni....does anyone understand what i mean?
Also how do i mount the rear sportlines on koni's?? it doesnt have a perch on the koni big enough for the sportline
In the back, you likely tossed out the stock perch when you installed the coilovers.
In the front...  I'm not sure what you mean.  Are you trying to get the Koni out of the stock shell?  Or are you trying to get the coilover sleeve off of the Koni?
im trying to get the coilover sleeve off the koni...
and i still have my stock struts....how do i get the perch off the old one? doesnt seem to want to budge
Are there set screws on the sleeves holding them on?  Those ghetto brands use all different methods of crap to try and keep them secured.
The perch comes off.  Try shooting it up with some WD40 and letting it soak for a while.  Then tap it upwards from the bottom with a hammer.
hmm ill check the set crews up....
thanks weasel i appreciate it.
yeah the rear perch bangs off with a hammer.
The sleeve, probably needs some coercion as well.
-da chinchilla
<img src="http://registry.gmenthusiast.com/images/jiggamon/avatar15569_2.gif">
coercion
n 1: the act of compelling by force of authority 2: using force to cause something; "though pressed into rugby under compulsion I began to enjoy the game"; "they didn`t have to use coercion" [syn: compulsion]
Or how about try coaxing instead of coercion.
-da chinchilla
