Hey guys I'm having a little problem with scraping..... I have a 96 cavalier with bomex kit, goldine springs (2inch drop), and 15 inch rims.....
I scrape in alot of places.... what would be the best way to raise it up a bit without getting rid of the goldlines? Like would 18s make a difference?
Thanks guys...
no rim/tire combination will help
because getting 18's with correctly sized tires, it will end up sitting at the same height anyways
get different springs
Yeah.  Your springs and the location of the perches determine your ride height.  Nothing else unless you're going with an air ride system and the air bags replace the springs.
Ok guys thanks for the info, it's really appreciated...
if you want to be a cheap a$$ you could get a spring spacer, it will raise you about an inch.  it won't increase your suspension travel but will increase clearance.
CAR GODS MADE THE 1.6 SOHC TO MAKE US 2.2 OHV GUYS FEEL BETTER.
