Is there anything I need to know before I do my suspension if in the long run I wanted to do AutoX.
Was thinking about GC w/ Koni Yellows, Eibach sway bars, Freedom Design Strut Tower Braces (front and rear)..Would there be anything else I would need? Or anything I should know about thier regulations before putting this setup on?
Also should say was gonna buy all polyurethane bushings too.
A second set of rims, perferably light weight, and nothing larger then 16's, and a good set of track tires.
And how are your brakes?
Are they up to the challange?
true.
Cannon fodder is my daddy.
would have to say probally not on the brakes.....after I brake "hard" one time they start to feel sloppy...but they were cheap generic rotors and pads
I just got powerslot rotors and Hawk performance pads. And im in love.
They are freakin great, id recommend them.
true.
get some strut bars and sway bars
   Try it stock, that is the best thing to do. You8 may put the strut bars in and rear sway bar and find that your in a different harder class then what you would have been if you left it stock.  I would also sugest using regular street tires or what ever you have now before you spend money on a second set of R compounds and rims.  You can only become a better driver by learning from a car that isn't set up to win.
Ryan Butchart  1 man, 1 car, 1 lap at a time.
