i have done a search (only found 1 person thats going to be doing it) but can't find any pics of a cavalier with an rk sport type j body kit with an air suspension, does anyone have any pics?
thanks
not the full type j but you get the idea.  also brad has a yellow 03+ cav w/ type j and now has bags but i dont think he has any pics yet
I will have pics tomarrow also both my backs are leakign and go down it is nto one or the other both what is the problem prob guy that instaled is goign to look at it tomarow but with it being both back it realy cant be bags or valve any clue all?
wow thats a long run on sentence.  im jus guessing that its leaking from the tank.  check all your fittings and make sure they are tight.  also check to where the 90 degree elbow attaches to the bag itself.  it could be leaking air from there also if its not tightend
did you guys install yourself or have them installed...and if you had them installed, how long did it take/cost? i'm getting the do it yourself kit from easystreet...and if install isn't too too bad i may try it with friends.
Grillrd wrote:did you guys install yourself or have them installed...and if you had them installed, how long did it take/cost? i'm getting the do it yourself kit from easystreet...and if install isn't too too bad i may try it with friends.
do it yourself.  me and 2 of my buddies did mine.  i had no clue about air suspensions when i started.  i knew how to swap out the suspension and all because i use to have coilovers before the bags.  its pretty easy and straight forward.  i think it could me like 5 bucks just for some gromets to run in the wheel wells so i could protect the lines running through.  we did it all in one day and took a total for 14 hours.
mine was leaking on the bag hopefully thats the only place it was leaking. pacrossbow  Iwill get pics tonight. also are u from pennsylvania?
Brad, yes I am from PA.  I live just outside of Scranton.  We will probably see each oher at shows as my 05 cav is due back from the shop the 3rd week of this month.
well i will be at hershey this weekend and state collage next weekend u see my car yellow 03 I am in the car club optical ilussions realy big guy so hit me up and say hello any one
