Has anyone used the SSBC rear discs with stock 16" rims?  I thought I remembered someone doing this, but their site lists a 17" necessary.  I am just trying to decide between this kit and the Baer kit since that will work with stock rims.
"If you aren't shifting, then you certainly aren't driving!"
I tried, but the only way to get the wheel to clear the caliper is to push it away from the hub with a spacer & even then there is around 1/4" clearance. Works well enough for winter though as you can see in the pic.
