Are all rear strut bars the same for 95+ the same? Thax in advance.
They should be.  Gravana Tuning shows the same part numbers for all years.
yes
Yes they are, but you might need to buy an extra nut for mounting.
I bought a Vibrant rear STB, and on my 2002 cavy, the rear strut mounts have 2 funky round nut things (I couldn't unscrew these without messing em up), and a real nut on the 3rd mounting screw.
Luckily I had 2 extras laying around I just screwedthe STB down on to those round threaded washer looking things.
those two round nut things are the two bolts coming up from the bottom, you will need two nuts to fit on them to hold the plate down in place. its a metric 8 but I don't remember off the top of my head the thread, its either  course or very course as i recall. if you take your torque wrench with you you can take of the front bolt at the auto store, and make sure that it will thread onto the bolts, them it should fit just fine. just don't forget to put th bolt back and torque it to 18 ft lbs before you leave.
