What kind of brake fluid does the 1996 Z24 take? I hear its DOT 3...Am I right?
I wanna take out the old fluid and replace it with new fluid. What are the proper instructions for it? I have a brake bleed kit from Canadian Tire.
The Chronicles of Dust
View the website and read the Novel.
http://dustnovel.webs.com
yup. it says so on the cap. pop your hood, located the brake fluid and the cap says dot 3
Oh ya crap i did not see that...lol
You can also use DOT4, which is compatable but has a higher boiling point.
You can NOT use DOT5, which is not compatable.
What color should this liquid be? Mine is brown now.
Golden like clean motor oil, when it's clean.
crap ok its time to do a bleed....thanx for all your help...
Wild Weasel wrote:Golden like clean motor oil, when it's clean.
really, the stuff i get is clear.
i just had my brother flush my brakes. nice new DOT4!!!
Land Pirates sail the open roads
DISCLAIMER: If anything I say offends you, I don't care..wear a helmet. Also, the information
I post is what I know to the best of my knowledge. If I am wrong, please correct me so that
others as well as myself may learn.
Premium sinc 6-17-04
haynes manual has good details on bleeding. i will actually be bleeding my brakes on monday.
"Official Jewish J-Body"
well bleeder valve was rounded off so i just bled out of the brake line. wow did it make a difference. no more clunking and a nice firm pedal.
[quote=ßãggéÐÇåv98 (Ûñqùðtäß£è Øñé)]
Ok then... clear with a hint of golden like clean motor oil?
well i was just double checking. i was starting to question myself.
heh. Same here. Haven't looked at any for quite some time now and just recalled it not being clear since I could see it through the hazy plastic of the reservoir.
Bottom line is that when it's dirty... it looks dirty.
