Well okay guys i still have a squeak in my suspension in the rear, is there any chance that some of the fitting needs something to lube them up to keep them from rubbing?  I know the struts arn't bad because it dosn't makie a thud sound just a squeak like a rusty door hinge or something its annoying as hell i've pondered on bad strut mounts but i've only been lowered for abour two months now and i've heard that the rear strut mounts arn't that troublesome, so what do you guys say?
btw i have an eibach prokit and kyb agx struts.
I have the same type of squeak every once in a while over bumps.
I've only been on this setup less than a week.
Was wondering about mounts also.
Or, I was also wondering... my stock fronts had rubber insulators on the spring perches but the backs didn't.
Were yours this way?
I'm thinking this is where the squeaking is coming from.
Yeah I also have a squeek happening on my front passenger side, lol no idea as to what is causing it.
seems like a common problem i orderedd kyb strut mounts today and i sould be getting them in by monday and installed thursday i hope this works if not i'm going to go crazy by this annoying sound.
i found the squeak it was in my rear strut mounts.
Put some greese on your bushings in the rear. Should take away all the squeaking.
