I was wondering what type of battery I should use as my second one for my air setup. I had a yellow top and it didnt last too long. Any help is appreciated
Norms Fenders
Holes in front bumper from plate bracket (custom)
Solo Hi Flow Cat/ 3in dual exhaust
Kappa Intake/IC Pipes
Pcm4less Tune
Infinity Kappa Speakers
Dakota Digital EGT & Boost Gauage
DDM Probeam
JPM Shifter
Custom Kicker System By JPM
MBRP Heat Shield
Dejon Intercooler
AlkaControl Water/Meth Injection
im usin' a regular pep boys battery.  ac delco and it works fine.
I have an ac delco and i have to take it to get charhre all of the time.
Norms Fenders
Pcm4less Tune
DDM Probeam
JPM Shifter
MBRP Heat Shield
Dejon Intercooler
thats weird, i have a mine set up to that and i never had a problem w/ it
try a better alternator that might be you problem thats what it sounds like to me
well i have an 180 amp alternator so i am not sure what is wrong. It could be because i play with it so much that it cant keep up.
Norms Fenders
Pcm4less Tune
DDM Probeam
JPM Shifter
MBRP Heat Shield
Dejon Intercooler
 sounds like your having more problems than your telling us.lol. i just used one yellow top on 2 compressors. and had no alt upgrade or anything.worked fine for me.good luck
my motormaster eliminator has worked fine in my car for the past 2 years
Phil Thacker
JCO North President
If been running two viair 450s on a yellow top with no trouble.
I am all that is man
im running a 500watt amp and plan on getting Air next week.... is it manditory that I get a second battery or will I be fine just running off my one yellow top??
you dont need a second battery at all.  a yellow top will be fine.  they are alot better than regular batteries.  i just replaced my one battery after 2 years of having air and i think the low battery charge fired my wiring to my pressure switch.  good thing i had to fix something cuz that wire was burnt up for some reason
Is it a good idea to lay down some Sound Deadener in the trunk for the tank, compressor ect???
w/ my back seat up and my radio on, i cant even hear the compressor kick on
okay cool, so i shouldnt even worry about my tank or compressor vibrating from the music or even just the compressor running?
your not going to feel any vibration.  if anything youd hear a very low humming noise
