alright so i had n alignment about 3 weeks ago.  up to the beginning of the week, the car has felt fine.  then it suddenly felt like it wanted to go off to the left with the wheel straight, but with it slighty turned to the right, it would stay straight.  then i checked the tires and saw the front pass side had some wear on the inner tread.   today i rotated the tires to see if that would make a difference but instead it made it worse.  i was on the highway and anything above 50 the car felt like it was having seizure. it was shakin alot. now i think im gonna switch the tires back to the way they were. i have noi idea as what to do. do i need new wheel bearings or something. i dont see how its the alignment because its not too long ago that i had one.
please help me out i dont have a clue as to what to do
You have to check the tires on how they are supposed to be rotated. Some tires should only be rotated from front to rear on the same side (passenger front to driver front, vice versa) and not side to side (passenger side to driver side, vice versa).
oops correction...this is what I meant to post:
NJHK wrote:You have to check the tires on how they are supposed to be rotated. Some tires should only be rotated from front to rear on the same side (passenger front to PASSENGER REAR, vice versa) and not side to side (passenger side to driver side, vice versa).
yea thats what they did.  they took the fronts and put them on the rear. now anything over 50 my car feels unstable and shakes alot.  could it also be from the car being a little uneven because i need to change the rear strut mounts and i think the back might be a little lower than it should be . also yesterday when i stepped on the gas a little i felt the rear go down a little.
i took it on the highway today to check it out again and the car felt horrible like it was goin side to side in the front.  then i jus looked at the car itself and  it looks lopsided. the passenger side is higher than the driver side.  im guessin this is the problem and that i need the sturut mounts.  i also checked the Cv joints and tie end rods and they looked alright so hopefully its the mounts that need to be change and then i will be ok
Sounds like your toe is way off. Take it back and have them check it again. They should not charge you  a dime either.
well then i hope the toe being off is the problem and that it can be solved after bringing it back to the shop.  i dont want to keep driving around thinkin something is wrong with my front end
