Around bumps, passenger side in the front squeaks... Im guessing Strut mount or brakes.
could be struts, thats what was wrong with my moms car when that happened. im starting to think its happening to my car also
Could be several things. Most commonly: Strut mounts, Struts, Springs isolators, and Bushings.
Well i just replaced the bushings... and i saw how they went in... they were perfect once installed. My guess is the strut mount or strut. I pushed down on the car on that side and it still has resistance so the strut isn't blown completely, but the strut mount still creaks and cracks.
The inertia of the car will make it impossible for you to tell if it's blown simply by pushing down on one side, not to mention the other corners will move at the same time. The only real way to tell is to take it off.
If the bushing are all on the up and up, it's probably the mount; something very common to our cars.
Sweet thanks, I also noticed under heavier braking it does it as well... If that helps to pin point it.
