I was wondering is there any stack rear disk brake setups that I might find on a car at the junkyard that I could convert to my 97 z24. Also what other things could i find at a junkyard to gain performance?
There's a couple of write ups in this forum for converting Neon rears over for use on J's.
Both will require some machine work, but the first is a fair amount easier and cheaper than the second.
Neon Sport disk brake swap:
Linky
GM N-Body Independent Rear Suspension swap:
Linky
Also, a few people have done the Neon swap already. Only one person has done the IRS swap, but several are working on it right now. Both are fairly new ideas, and are still getting all the kinks and quirks worked out.
Thanks for the info I have a friend who owns the biggest junkyard with in 50 miles i guess It time to go shoping. What year Neon rear disk brakes or do you use the fronts?
^^ I was wondering the same
Purple Z wrote:Thanks for the info I have a friend who owns the biggest junkyard with in 50 miles i guess It time to go shoping. What year Neon rear disk brakes or do you use the fronts?
If you want to maintain use of your e-brake, you have to use the rears.
96-99 Neon Sports are what you're looking for.
CTS wrote:Neon Sport disk brake swap: Linky
Tolarences for having the backing plate milled are
here
