i got a addco sway bar and i went to put the u bolts over the axel housing and the holes on the plates dont line up any suggestions/what ppl have done.
I had to bend my A brackets to get them to fit in the holes. If the brakets are to wide, just pinch the ends down in a vice (while protecting the threads). If they are to close, just spread them out a little.
Yup you can do that.
Or all I did was enlarge the holes slightly.
EIther way it should be too much of an adjustment you have to make.
-M
I enlarged the holes a little, when there was some excess material when they stamped them out on mine and I couldn't even get the u-bolts to even go thru the plates.  A few minutes with the drill and they fit fine.
-Chris
