their probably not bad but obviously not the best.  if you buy them your gonna have to spend 600 bucks on yellows anyway so i would just get a decent setup from gravana.  they sell yellow packages with different springs and it will probably run you the same price and it will ride better
I already have koni reds. My dilema is that the HP Coils that are currently part of my setup are absolutly @!#$ and my car rides as if it's on rails. It's as if I have to suspenions at all.....and I tried adjusting-no luck. It's great sometimes but the roads out here are horrible. I want a slightly smoother ride without too much compromise to handling. The springs don't seem too bad at a glance....anyone else?
If you have the money, I would invest in a better known spring like the Eibach Sportlines (since it is apparent you want a 2" drop). Cheap springs are more likely to sag.
my sportlines rock and with these crappy milwaukee roads i think that it rides really nice but then again i guess im used to a stiff suspension. id say go for the sportlines with the yellows.
Monkey: He's got reds, they are just as good as yellows.
I agree that sportslines would be a good choice. Also the mantapart 2" drop, if that's what you're looking for.
Those springs will work, but are stiff (not as stiff as what you have now), and will sag over time (worse than high quality stuff).
Also Goldline and Sprint could be options (at 1.8")...
I went with the sportlines but I've run into a problem. I started a new post for it....
Click here
