Okay, so as a Product manager at Sport Compact Only I get exposed to several different great products, and this time I had to share.
We just started offering a new strut dampener kit for many Nissan and Honda applications which are getting alot of hype.
The brand is K Sport, and with their unmistakable Orange color, if you've seen them you know how nice they look. Well, apparently they also PERFORM nice too. I've heard only good things about them, and we've just started selling them here and already have had several orders.
THIS IS NOT A GROUP BUY, or even a plug for my company, but rather a desire to see if YOU the J-body community want more options for adjustable suspension.
I've included some clips from the SERBoard.com group buy, with some real, personal opinions on these new struts.
How Much: $1100 retail, kits for other applications go for about $850 + shipping.
Features: Adjustable spring pre-load, adjustable damper height, adjustable damping force, adjustable camber in front (slotted lower mounts, not camber plates), universal 2.5" I.D. springs. Front and rear upper mounts included.
Impressions: So far so good. I've put about 750 miles on them, so it's a little too soon for a durability report, but they seem very high quality for the price.
One of the features that drew me to these was the adjustable damper height. Some other brands of coil-overs feature the adjustable spring perch only, so for every inch you lower the car, you loose an inch of travel. With these you set the pre-load on the spring with the spring perch, and then adjust the height by threading the damper and spring assembly in or out of the lower mount.
This is the height I have been running since I installed them. I have at least 1" of adjustment left in the damper height at both ends, plus I could take a little preload off of the springs to get it another inch or so lower than that, but this is plenty low enough (maybe too low) for me.
(Yes I know my car is dirty)
The springs that come shipped with these are 7kg/mm in front (about 390 lb/in) and 5kg/mm in the rear (about 280lb/in). Having looked at the spring rates that came stock and the spring rates of other brands or springs that fit stock type struts I decided that these rates were pretty much backwards from what I wanted. The rear springs that ship with the kit are also slightly shorter than the front. I swapped them from the front to the rear anyway.
Every kit that K-Sport sells for any application comes with 7kg/mm front and 5kg/mm by default. That leads me to believe that they haven't done any real testing or tuning on these and they expect the purchaser to experiment for themselves or live with what they get.
In my opinion, 5kg is too stiff in the front. The handling seems ok, I haven't had an alignment put on it yet, but it does seem a little less willing to rotate. I chalk that up being to too stiff in the front. A car this low on stock type dampers may need springs that stiff to avoid bottoming out the dampers, but with adjustable damper height that isn't necessary. I find myself bouncing out of the seat on some bumps with 5kg/mm's in the front, 7kg/mm seems like it would be unbarable.
I'm going to try a pair of 3.5kg/mm springs in the front and put the 5kg/mm springs back in the rear. That will retain the f/r spring rate ratio that came with the car stock, but be a bit stiffer and still offer a livable daily driver ride. I may also raise the ride height 1/2" or so to restore some of the stock suspension geometry until I get around to building my ball joint and tie rod spacers.
Changing the springs on these is very easy if they are not installed on the car. With the adjustbale damper height, no spring compressor in necessary. All you have to do is unscrew the lower mount, the lower mout jum nut, the spring perch jam nut, and the lower spring perch. Then the spring comes off. All of that can be done with the wrench included in the kit. It's a whole lot easier than trying to break the torque off of the upper mount.
The damping on these seems adequate. I turned the front down 1/2 turn from what is recommended and the rear up 1/2 turn to compensate for the altered spring rates, and it feels good. I don't know where they come up with the "36 way adjustable damping" that they advertise. There are no discernable clicks in the adjustment so you pretty much go by fractions of a turn.
Also when installing these, PUT THE REAR ADJUSTMENT TOOLS IN PLACE BEFORE YOU INSTALL THEM ON THE CAR! The tool is about 6" long and it will not go in once the rear pieces are bolted in place. Ask me how I know.
I haven't bottomed out on anything yet. I did once, over a big dip in the road, hear a noise at the rear that sounded like a tire hitting the inside of the wheel well. I am running 215/45-17 Fuzion ZRi's that are probably an inch taller than the stock Conti's, so it wouldn't surprise me if they rubbed on something. I also had two tool boxes and a 50lb bag of dog food in the trunk at the time and the upper edge of the rear tires were tucked quite a bit into the wheel well.
On a scale of 1-10 I would rate these an 8.5. The only thing that keeps me from giving them a 10 is the lack of long term experience (with Tein or JIC you know their reputation for quality) and the questionable spring rates that they come with by default (if they had a "recommended" rate specifically for the B15 I'd be more impressed).
My Car Domain
that looks like its the factoy height!!!
you gotta pic of before they were installed?
They come with waranty for strut?
whats the total adjustmnent height?
wait for it... wait for it... NOW GO!!  ---> '02 LS Sport <---
Yahoo IM : buzz122          AIM : buzz122cav
I don't like the fact that they feature "universal spring rates". Seems kinda cheap to me.
I think the market is covered fairly well now with Teins, Ground Control, and Gravana's coils.
Its not so much "Universal" as "Choose your desired spring rate".  Most tuners know what they need as far as spring rate, and with a multitude of options available with only one strut you get the truly custom configuration you need for your application.
Visit
www.ksportusa.com for more information on warranties, registration benefits, and applications
My Car Domain
This is the ONE thing that has got my attention, and the one reason why all of the other coilover setups for the j-body SUCK-
Lowering without losing suspension travel, there's a THOUGHT
Okay, you asked for them, so here's before and after pictures.
Before
After
Before
After
My Car Domain
will those strut mounts work with any springs? i badly need a good set for my cav.
White Raven (Ryan L.) wrote:Its not so much "Universal" as "Choose your desired spring rate".  Most tuners know what they need as far as spring rate, and with a multitude of options available with only one strut you get the truly custom configuration you need for your application.
Visit www.ksportusa.com for more information on warranties, registration benefits, and applications
BWAHAHAHA!  Not on JBO, they don't...
But other than that... sounds cool
There aren't that many choices out there for j's (comparatively speaking)
rk's setup= height adjustable only
tein's setup=height adjustable only
gravanatunings setup= not out yet, but dual height and dampening adjustable (very similar to these)
So do you guys think you would be interested in these? I mean, if I can get enough interested drummed up I can convince them to make us an application.
My Car Domain
If you want to drum up a list of people to have them made, you're going to have to get a premium membership and run a group purchase.  That's how this sort of thing is done around here.
Basically...  if it's a good deal, you'll make money.
I don't think the market is worth it, especially if your only marketing thru the JBO.
Teins now feature height and damper adjustment.
Many like me who are serious about suspension are going to go with  Gravana (german engineered), Tein or RKSport.
Because...  all those companies actually took time to research and build the coilover sets and spring rates for our cars.
I've been autocrossing for over 2 years.  Ask me what spring rate you think  I need and your going to get a blank expression.
We pay the premium for the research behind the components so we don't make get something that won't work, or isn't sufficient.
Now if you were willing to do testing, and reasearch the best spring rates.  You may have a chance.
-Chris
On a second note it looks like you guys make Lower Control Arms.  As of current we don't really have any options..... that don't break at the welds.  That could be a very possible market.
-Chris
I have had experience with these in the 240 SX forums.  People seem to think that they are kinda cheap, make a lot of noise, etc....   I don't know.  If anything, I would love to see more options, esp. one like this.  Monotube design is great.  If I could see any company bring a nice suspension such as this to us J guys, I would personally love to see D2 or Megan Racing bring their coil-overs..  D2 is great for the track and the MR ride really well.
I'll have a sig someday....................
Nissan for sale drop me a line!
he doesnt work for them , he works for sport compact only
k-sport is a local company to us he in az
they look pretty sweet , and if they make camber plates for the front and plates for the back , that would be sweet
hell even just the front and rear upper mounts would be sweet
I need camber plates bad too!
