Hey i was wondering where you guys ran your lines from the front and rear struts.  Should i just follow the fuel from the front to back?  And where is safe to clip the line to the wheel well, where it wont rub? Anyone have pics of their line setup?  Thank you guys!
hmm i never got around to taking pics but if you search in this forum there have been threads about air lines so you'll find some pics.  basically this is what i did.  on the front struts i ran the line down the wheel well and under the car.  i zip tied it right at the bottom of the wheel well (theres a hole there and i ran a zip tie though that and secured the line.  then as you run back to the back, right on the other side of the pinch weld there is a rail that pretty much as holes all down it so i zip tied to that all the way down.  when i got to the rear at first i had the lines from the front struts coming up through the trunk floor but later changed it due to problems.  i have the front and the rear lines meet up right at the back of the rear wheel well and i drilled through the back of it right into the trunk and its right there.  just make sure when your passing the line through metal, use rubber grommets
i run the lines inside the car   keeps the lines safe from any road debris  and make for a cleaner install
can i haz bondo
