aight i picked up  a rear strut bar.... just one thing how do i install it... i have a front which was easy remove three bolts and replace but how ab out the rear..... if there is someone out there that can let me know it would be awesome...... peace
I just used proper sized Hand wrenches.   Takes a little longer, but it works.
^^^ why do you have gauges in your engine bay??
Scotty B wrote:^^^ why do you have gauges in your engine bay??
and a fuel filter in your intake hosing?
Simple, so i dont have to keep running back and looking through the window to see what the engine is doing.
There is also a FP gauge, and A/F ratio gauge in there too.
And as for the fuel filter, its chaeper then getting a catch can, and cheaper to replace then a breather, and i can see if any more then usual oil passes through there.
It doesnt look like you spend enough time under the hood that you NEED guages in there. What do you do when your driving and you need to see whats going on, pull off to the side?
Scotty B wrote:It doesnt look like you spend enough time under the hood that you NEED guages in there. What do you do when your driving and you need to see whats going on, pull off to the side?
Nope, i got the same gauges in my pillar pods.
The engine ones are for mostly tuning and show.   Extra show points is always good.
umm guys maybe i am stupid but where are the bolts.... under the carpet area inside the truck or do i have to go underneath the car... sorry guys i ain;t that incline when if comes to autos....... peace
inside the trunk. remove your carpit  to view your strut area. there are 3 botls on top.
Yup,
And only one of them actually has a nut on it.
You'll mount to those.
Maybe even go grab a 5/16" lock nut from somewhere for the other stds pointing up back there.
Have fun,
-M
i'd definatly mount it to the studs as well. just as an extra support i guess. its not hard. to do, might bust a knuckle or two. if you have wratchet wrenches it'll be cake...
GO PATS!!!
