may friend has pics of a caviler that has a 3.4 dual over head cam  motor in it i want to know  what trans do i need and  what  wiring would i  need to do this swap in to my 97 sunfire gt 5 speed  i got a junked 97 monte carlo at my shop with the trans gone i can buy the car for $700cnd any help ???
rwd sunfire
the 3.4 DOHC is useless.  Plain stupid to swap it IMO.  the 3400 or 3.4 is different.  Not all 3.4 are DOHC in case you didn't know.
You have 215hp from a block of concrete (3.4) and you can get the same thing with about half the weight of the 3.4 with a W41 2.3.
Gilles
2.3 Ho
go to w-body.com, and PM aaron about his car. HE has an all motor 3.4 in a 3400lb car that ran 14's on a @!#$ty tune.
The 3.4 is a very versitile engine, and one of the more reliable. Just check the condition of the timing belt, the tend to need replaced every 60k miles, or boom. Ask areound w-body, you'll get alot of help, they know their stuff, they know TOO much.
PS; a w-body is a
88-present grand prix, regal, cutty, 1990-present lumina, 1995 monte carlo-present, olds aroura, etc
1971 camaro 427 --- here!
Stock... and loving every minute of it.
Too bad the W41 quad is that fast stock, and takes mods better than the 3400 will, and weighs about half what the 3400 does.
3400 and the 3.4 DOHC are totaly diff engines. the 3.4dohc is an overjhead cam engine, while the 3400is a pushrod.
Engine Description  	(LQ1) 3.4L DOHC 60 degree V6
Horsepower (HP@RPM) 	210@5200
215 (1996)
Torque (ft-lbs@RPM) 	215@4000
Block 	Cast Iron
Heads 	Aluminum
Valves 	24
Displacement 	3.4L (3350cc, 207ci)
Cylinders 	6, V formation, opposed 60 degrees
Bore 	92mm (3.622")
Stroke 	84mm (3.3122")
Compression Ratio 	9.25:1-9.5:1
Fuel Management 	PFI/SFI (Sequential Port Fuel Injection)
VIN code 	X
Usage 	All, 1991-96 (exc. Buick Regal)
Type 	Gen II Dual Overhead Cam
I never said a V6 swap was useless.  I said the 3.4 DOHC was useless.  You have 215hp with the 3.4 DOHC and you can get more power from another V6 with less work.
Another thing, do more research.  the 2.3 can be streetable even with 500hp.  Bilmar did a 2.3 with the same power as the 3.4DOHC, weight half of the 3.4 DOHC and you get the same potential.  I would go with a 3.4 OHV way before the 3.4 DOHC so please, read correctly before getting on me.
Gilles
2.3 Ho
Settle down, fellas! We don't need another flame war, and you guys are going WAY off-track. He never asked if a 3.4DOHC swap would be better than a quad-4, but asked what he would need if he bought that cheap parts car.
I don't have the answers, but someone here must have. Nothing came up when you searched for V6 swaps?
Chamillionaire wrote:
I'm being who I am, not what you want me to be...
ask doublezed aka brad about his 3.4 dohc setup.
listening
2004 Cavalier, 2.2 ecotec, 5spd getrag
do you ever notice that the ones who talk the loudest have the least to talk about?
