ok so this is waht has happened! i have stuck witht eh h.o. rebuild block everone said it should be fine , (thank you bagefire) i have a head i got with the car when i bought it, it was from RSM port and polish all new parts casting # 24575456 i know it is not the 086 head but for free i will take it and better then stock, full headgasket set from felpro, and new headbolts from felpro, new water pump, (thermostat if you care to know) and the ho intake and tb, i order polly urithane lower engine mount and upper insert from apluspreformance and the group rate, (thank you jason) now i have the cams and cam towers, i am not sure if they are from a just an h.o. or a w41, as best as bagefire can recall, the motor came from a 92 442, i have the computer hear on my desk i am going to put it in with the cams, it has 2 big plug on the back a long black one, thats seems to be split in 2 parts aswell the yellow plug, the number on the sticker on top are as followes,
SERV. NO. 01228707 ANMS
865213 M911773007
16125213 ANMS
(INSERT A BAR CODE HERE)
*865213M911773007-
YHA O KNOW I REALY NEED A DIGI CAMERA well maybe you all can help me out, i am goin to clean up the cams and towers, and drop them off they are going to start on monday    but hopefully be done by tuesday night or wensday
also the exhaust mani is there any difference from the ho to the lo ???
I think I missed the first question up in that huge run-on sentance... Try a couple periods in there, maybe even a question mark, it'll make it easier for us.
As far as the second question (if there even was a first), yes, there is a difference in the HO exhaust manifold an the "lo" one.
SORRY, THE QUESTIONS IS A I HAVE A 95 2.3 AUTO, i have now the ho cams, and intake and what not. the computer i got with the cams is discribed above, will i be able to just plug it in  or will i have to rewire anything?  I do not have access to my car right now, so i cant just check.. I know there is something with the amount of plugs on the back of the computers, 2 or 3 plugs, OBD I to OBD II kind of thing. As to use both ho cams i believe that i would need to use the comp aswell.
