i don't know if anyone has thought of this, i didn't bother searching or even try and figure out where this post could go, but would it be possible to foam fill the frame? I mean it is tubular in certain area's, and the only thing i can can think of to get the foam in there is to use a two-part mixture foam sealer (liquid then expands), i may just be talking out of my butt,, (that's what 5 years of being in the Marine Corps will do to you, especially when you deploy a few times to certain countries) anyway would anyone on here think this would be possible. thanks for any responses. Semper Fi!
I saw some guys do it on Street Tuner Challenge (I think it was that show anyway) to a Volkswagen (Again, I think). I don't know what 2-Door Cav's and Fire's are like, but on my 4-Door, this could be done in the rocker panels and the support where the rear doors are hinged. Anywhere else I'm not sure.
ask dave, he did it, and said there was major sound reduction.
I did it to the front frame rails... easy as pie. Stick tube in, spray. Makes a hella mess when it comes out all over the place tho. There's quite a few holes I didn't know about.
I haven't done the rear... but there's lots of access holes from underneath.
Excuse my ignorance, but I've never heard of this. Are there any other benefits besides noise reduction, and roughly what kind of wieght does it add (not much I'm guessing)?
http://sportcompactcarweb.com/projectcars/0006scc_proj300zx/... read this article. they used a product specifically made for this application. here's the link for that:
http://www.foamseal.com/auto_aftermarket.htm. it's about $200 for enough to complete one car.
the major benefit is strengthening the chassis, but on a j-body i could imagine that it would help with noise reduction as well. i've been wanting to do this for a while now, but i have never been able to justify the price and amount of time it takes to do, considering how little i drive my car
Juicez99cav wrote:listening..........
X2
Very cool! I'll have to do some more reading on this, lord knows our cars could use some stiffening and noise reduction.
hey i appreciate the comments, i thought alot of jbody owners have done this, and with that the guys who have done this could you tell exactly what and where i need to make holes to inject the foam, and if at all possible provide some pictures if not that's ok. The only reason i brought this topic up was looking at the new ford F-150's, they have foam filled frames to make the ride quiter, so i thought it could be brought forth and applied to our current J-bodies. thanks guys keep in the info coming
Come on Lenko, you have to have pictures on this!
Believe it or not, I don't. That's gotta be one of the few mods I DON'T have pics of.
any potential moisture issues with doing that?
14.82 @ 97 mph
As long as the foam is non hygroscopic it shouldn't be an issue, and since it is closed cell I bet it is. Start with a relatively dry car and it should be okay....
What type of weight gain would you see from adding all the foam? This is something I have only seen done but have always wondered about.
Proud member of
JBOK (J-bodies of Kentucky)
Good question, What about moisture? Any rust issues?
Weigh the spraycans if you are that worried about the weight. The stuff expands like crazy, I couldn't see using more than 6 cans per car, for every nook and cranny, so at most maybe 5 pounds of weight gain.
edwardsmr2002 wrote:Weigh the spraycans if you are that worried about the weight. The stuff expands like crazy, I couldn't see using more than 6 cans per car, for every nook and cranny, so at most maybe 5 pounds of weight gain.
I agree the weight gain should be minimal, but I'm very interested in the chassis stiffening and noise reduction benefits of this! If anyone has any pics, or will be doing this soon and could take pics that would be great. I'll be looking into this more closely when the snow melts.
could you use the expanding foam in a can you buy at wal mart or advance auto parts?
I Drank 750 Bottles Of Mountain Dew For A XBOX 360.... AND ALL I GOT WAS THIS STUPID HAT.
from what i read on that article that was posted by Brown eye, it seems very feasable if you use the right stuff and for $183 total for 5 cans, it's a worth while investment, it's just a matter of finding the time to take everything out of the inside of the car stagging it and then doing the foam injection, but all in all it's a very good performance mod. cause being out in cali all the roads out here suck, potholes and cracks. keep the comments coming, appreciate it all.
can we make a list of all the benefits?
LE61T PTE6262 Powered
i was thinking about using great stuff would that work?
Dark Drake wrote:i was thinking about using great stuff would that work?
That cheap crap foam may fill your frame with foam, but won't provide the chassis stiffening and noise reduction benefits that you're looking for, so what's the point. If you read the article linked above, it says "DON'T CHEAP OUT ON THE FOAM".
ScreamSayonara wrote:I saw some guys do it on Street Tuner Challenge (I think it was that show anyway) to a Volkswagen (Again, I think). I don't know what 2-Door Cav's and Fire's are like, but on my 4-Door, this could be done in the rocker panels and the support where the rear doors are hinged. Anywhere else I'm not sure.
it was the skyline they did it to , and it was for the added rigidity
im not sure if they did the VW or not if they did it was for sound reasons
I've done it only inside the cab, on both my Cav (a long time ago) and my Sunfire (recently). Along with dynamat on the entire floorboard it reduced road noise levels immensely. It did also stiffen the cab just a tad. Its not spectacular, but the car feels just a bit better in corners and on rough roads.
