i got a 2.2l OHV and my car won't start ran great but no i have no sprak it's got new plugs and wires in it was runnin great came out of work started up and then cut out and now it won't start
It rolls over but no sparl what would cause this ?
No spark
Do you have 12V at the module, voltage at the coil?
i dunno can i check that with a multimeter ?
well i changed the coil pack still nothing anybody think of somthing ???
the car rolls over just won't start the fuel pump and everything is good just got no spark coming from the wires
could be a CAM or CRANK sensor, ign module, ... Like stated above, do you have power at the module??? How are you checking for spark??? You may be doing more damage if you do not know what you are doing.... Diagnose it, dont throw parts at it...
P&P Tuning
420.5whp / 359.8wtq
I recently had this problem. Does it have a clicking sound when you try and start your car? If so, then your starter would be fine. Mind turned out to be a loose wire on the starter. Took me about 350 to figure that out. New battery, alternator ... and diagnostics at the dealership.
dan
