when i start driving, its drives fine, then after about 15 minutes of driving, is starts to grind going into the gears, it still goes in the gears, but grinds a lil bit.....and idea what this could be??
I had the fluid flushed and changed when i bought the car about a month ago...
flushed
 ouch bad move. never flush anything other then the coolant. always DRAIN AND FILL thats it
So what should i do, put some oil stabilizer or something? do they have any performance trannys out that bolt right in? cause i race at the track a lot, and with my driving, i might need one soon....
no bolt on trannys i believe youd have to build one yourself it sounds like your tranny is on the way out tho.  Those "flushes" are never good for your car ive heard tons of bad things about flushes in trannys and engines both. Where did u take it are you sure they used syncromesh? i would drain it and do it yourself and use the correct fluid and see if it happends
I used B & M trick shift full synthetic, my 5sp shifts much much better than with the GM syncromesh stuff.  Read it on this site. Good stuff. Never flush anything except coolant, drain & re-fill like above states. Also, if you have the crappy Dex-cool orange/pink stuff drain/flush and refill with normal green coolant. I got burned on my wife's blazer with that crap. After it gets over 2-3 years old it forms Jello in your system. Clogged the blazer's heater core & lower radiator. Had to get them "hot water power flushed" to get that crap out. Friend works at a radiator shop, said it happens all the time. When he flushed it out, i just could not believe what came out. Never had that problem with Presone green...etc
Don
What car and tranny? If its an auto..do you shift it at the track?
Blown.
If you fill out your profile it's easier for us to help ya 'cause we know what your car's data is.
Don
Only Prob i've ever had with mine is a slight thud/bump when going from park to drive, though i've got a 4 speed auto. People tell me it's an economy car not a lexus or a bmw haha though i still don't think that slight pause/thud/bump is normal my car seems to have a variety of issues maybe it's posessed LOL j/k
Tranny mount or motor mount, also are tranny mounts a common prob with 03-05 Cavys  what are some of the symptoms.What is the end result when it finally goes away entirely does your tranny go out etc.
