I have a 2002 cavalier that has an 8 valve sohc head.  I have been wanting to upgrade to a 16valve dohc head.  What are my options and where can I find something like that?
You can't, and yours is an 8 valve OHV, not OHC. If you want a DOHC engine, you have to swap the engine out for one with DOHC stock. Pretty tough to run an engine with 3 cams (2 cams in the head, and the stock one in the middle of the engine).
Thanks for the help I'm sorry I didn't quite know what I had I'm kinda new to the whole cavalier thing but I very thankful that I have finally found a place to get credible advice because most places aren't too friendly to us jbody enthusiasts they are only concerned with Japanese tuners.  Thank you all for your excellent help
we'll be even more friendly when you learn to use punctuation...
GO PATS!!!
Hmm... this post makes me wonder... could you swap the Quad 4 head from the 2.3s onto a 2.2? Somehow I doubt it buuuut.... discuss.
I was happy when I heard my car ran 10s. Then I found out that was 0-60.
J H wrote:Hmm... this post makes me wonder... could you swap the Quad 4 head from the 2.3s onto a 2.2? Somehow I doubt it buuuut.... discuss.
answer...
Shifted wrote:You can't, and yours is an 8 valve OHV, not OHC. If you want a DOHC engine, you have to swap the engine out for one with DOHC stock. Pretty tough to run an engine with 3 cams (2 cams in the head, and the stock one in the middle of the engine).
2.3L is a DOHC as well...
GO PATS!!!
BECAUSE THIS TOPIC IS CALLED "HEAD" AND THATS THE ENTIRE REASON WHY I READ IT
, dont forget to grab the 2.3L/2.4L tranny of your choice
P0234- Only Code worth ever coming up on ur Scanner
www.sounddomain.com/id/935speedrs
You have the LN2, 2.2L pushrod motor.... in a 2002.... so you have the most options in terms of swaps....
You can go to a 2.4L Twin Cam aka LD9... get a 2000-2002 motor and transmission (the same Getrag F23 you already have, but with the right bellhousing... grab the engine wiring harness and the computer at the same time, and stuff it in the car.... bam, everything else except the exhaust will hook up pretty easily.
Or, you can go to a 2.2L Ecotec... get an 02-05 motor and transmission (again, same Getrag F23 you already have, but with the right gears and case).... engine wiring and computer, bam done....
Get the stuff collected ahead of time and some friends, you could have it done in a couple of days if someone knows what they're doing....
