98 Cavalier 2200, 5 speed
I have been having a problem starting my car.  The dash lights up and everything works but the starter will not engage.  Usually I pop the hood and twist the battery terminals and it would usually start after that.  Although it has been taken longer and longer.  I just put a new battery in it beacuse the terminals were stripped on the battery. It also has new cables.  I cannot get the starter to engage.  I want to test tomorrow to see if I am getting power to the starter. Anyone know how to do that\?  If I do get power to the starter, it is the starter??  Any other ideas would be great.  Thanks rp
also the car can be push started.
Bang on the starter with a wrench or screwdriver while you have someone turn the key.  If it starts fine when you beat on it, it's your starter.
Rob
 Sold 2/2/05
Sold 2/2/05
Has a new starter.  It will start when I jump the starter.  I put a screwdriver in the positive terminal on the starter to the starter switch post on the starter.  Possible ignition or clutch switch?? Thanks for responding
Dead Batt? Put a volt meter on the batt and crank the engine, see what volts it reads.
battery is good and brand new.  It starts fine when I jump the starter. Somehow the key won't start it.
Possibly a bad relay.  If not, then i'd say it's the ignition switch.
I would guess that it is the clutch switch. Just check it with a multimeter to make sure!
Problem solved, clutch safety switch was shorted.
