I have owned a couple jbodies and have done lots of work on them in the past whick include some engine swaps ( ln2 to ld9, and 97 ln2 to 2000 ln2) so i`m sure that with a little help i could do the swap. I`ve searced an haven``t seen anything like this done in a 95. Because its obd 1 would i have to run and ecu and wiring harness out of a second gen, or would it work just doing the swap like those who have done it in the obd 2 third gen`s?
any help would be appreciated,
There's a post a few posts down currently, started by a gentleman that did the swap, in a 95.
At either rate, it should be practically the same as the 96-99 models.
you probably havnt seen it done in a 95 before because a 95 is a PERFECT car for the 2.3 HO swap .. and since the HO makes just as much power as the 3400 but is lighter and takes less work and $ to do i can see why its perfered ....but if the 3400 is what does it for ya then proceed with posting pics
it should be just the same as any 95-99
