Ok 02 cavalier, 2.2l vin code "4" ....cars running great no problems, about 60,000 mi on it , wife got in it yesterday , it wont start. turns over, and over , and over. Ok so I checked spark, great, good compression, hmmmmm no fuel . checked fuse and relay, put new relay in just to be safe, dropped tank. power to fuel pump harness plug on body , power to fuel pump plug (fuel pump end). swapped pump, yea...............
...nope,. f'ing thing wont start. pump isnt coming on at all. tested power to fuel pump plug again, 11.5 volts for 2-3 seconds then drops ...normal right? well, plugg in to pump, and nothing. run two jump leads from battery to propper terminals on pump s harness, and it flows like crazy. what am I doing wrong???? I am stummped
copied and pasted from GM inside news
I had the same problem.
Subject:Crank, No Start, Low or No Fuel Pressure - kw C200 connector crimp 2.2 2.4 L61 LD9 LN2 power pump stall terminal #PIC3189A - (11/12/2004)
Models:.
The following diagnosis might be helpful if the vehicle exhibits the symptom described in the PI.
Condition/Concern:
Crank no start, low or no fuel pressure.
Recommendation/Instructions:
If you have low or no fuel pressure, check for proper voltage at the fuel pump connector. If you DO NOT have proper voltage, then inspect connector 200 (located in the drivers side kick panel) terminal W for proper terminal crimp.
Note: This is a grey wire in terminal " W " There have been cases found where this terminal was melted because of the poor terminal crimp. Inspect and repair this terminal and retest operation if same condition then continue on with SI Document # 859854.
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. If these steps do not resolve the condition, please contact GM TAC for further diagnostic assistance.
Models:
(99-05 Chevrolet Cavalier) and ( 99-05 Pontiac Sunfire)
email is the best way to get ahold of me
where did you place your ground lead of you terminal at?, If you touched it to the body and not the actual ground in the plug then you couldve missed something, the ground.
When you have voltage at the pump connector and your pump doesnt work then you need to look for ground. Use an Ohmeter and see if you have continuity.
If you did use the ground at the plug and got that reading then let me ask you if you bought an aftermarket pump? Could be DOA
