I recently bought a set of HID headlights for my car, and after installation only the driver side headlight works. So after doing some research on the issue, i've found that i need to disable the DRL to make the passenger headlight work. I looked it up and i'm doing the method that involves splicing the wires at the relay. I've located the relay and got the plug out, but i want to be pretty careful about splicing the actual wires. On the plug i've got a green/black wire, a black wire, two orange wires and a dark blue wire. Based on the diagram on the relay, i think the wires i need to splice are the green/black and the blue, but i wanted to be sure so i figured i'd come ask. Thanks for the help.
The instructions are pretty self explanitory.... 30 to 87a. Not hard.
Jon Mick wrote:
i find it amusing that SHOoff has nothing better to do but follow me around & be an unhelpful dick in even cross-forum.
well i dont see as well as some, so i didn't notice at first look that the wires are labeled right on the plug
. Sorry for the stupid question.
well now i've get that issue all ironed out and have power to both headlights. but of course now i've got another problem. The lights seem to be stuck in the high beam position and won't switch to low. They are bi-xenon 9007 bulbs so they should be the right bulbs. Any idea what might cause this?
