Does this look bad to you? - Third Generation Forum
Sunday, April 04, 2010 11:44 AM
I bought this tranny for cheap , only 11k on it for $100, the only problem was this cracked side pan, it's only about an inch long and not very deep. I was just curious as to if I could possibly by a sealer and seal it up or spend the money and get a new pan. Here's some pics of it, excuse the crappy image, they were taken with the crackberry.
I'm not going anywhere just yet
R.I.P. Jimmy "the Rev" Sullivan '81-'09
Re: Does this look bad to you?
Sunday, April 04, 2010 12:37 PM
nothing a little quicksteel cant fix
Sunday, April 04, 2010 12:49 PM
I doubt you will get a weld to stick to a case like that given its been soaking in trans fluid for its short life.... More than likely its impregnated the aluminum. If thats the case, a regular TIG weld wont stick, Quicksteel sure as heck is not going to stick, or any other adhesive for that matter.
I would start looking for a new side cover... Looks like a CV shaft replacement injury anyway...in which case those splines on the output shaft are probably muddied up too.
Sunday, April 04, 2010 4:01 PM
you could have that welded without any issues if the person welding it knows what there doin a good welder can make it work
JBO since July 30, 2001
Sunday, April 04, 2010 4:07 PM
Is it a 3 speed or a 4 speed? I have a spare side cover for a 4 speed sitting here. I'll let it go for next to nothing.
Sunday, April 04, 2010 4:46 PM
Its a auto not a manual. I'm going to make it into a manual just not anytime soon
Sunday, April 04, 2010 5:27 PM
Is it a 2 speed or a 4 speed? Does your shifter say PRND321 or PRND21
Sunday, April 04, 2010 7:55 PM
Its a 4 speed I believe its from. 2.2 auto from an 04 sunfire
Edited 1 time(s). Last edited Sunday, April 04, 2010 7:58 PM
Sunday, April 04, 2010 8:44 PM
Brian Online
CAVETTE wrote:Is it a 2 speed or a 4 speed? Does your shifter say PRND321 or PRND21
You mean 3 speed. Not 2 speed. If theres not any vacuum connections then its a 4 speed.
Sunday, April 04, 2010 10:31 PM
4 speed + overdrive
