what Radiator does everyone use - Third Generation Forum
Thursday, August 19, 2010 4:18 PM
im working on droping in a 3100 in my cavalier and wanted to see what Radiator eveyone used and works best with swap
also what Radiator hoses are u all useing
Re: what Radiator does everyone use
Thursday, August 19, 2010 4:43 PM
use a j body rad but if you have a single core rad swap it to the double core rad, its a little thicker hold and cools more coolantno idea what hosesthere using but i bet its either what ever J body hose you have or the 3100 hoses this kinda thing you can do on your own with out us because if you have the engine in just test fit it trim them if need be its not hard
JBO since July 30, 2001
Thursday, August 19, 2010 5:26 PM
ok well motor going in this weekend ill try to use my eco rad
Friday, August 20, 2010 2:49 AM
NOTa2_4 wrote:use a j body rad but if you have a single core rad swap it to the double core rad, its a little thicker hold and cools more coolantno idea what hosesthere using but i bet its either what ever J body hose you have or the 3100 hoses this kinda thing you can do on your own with out us because if you have the engine in just test fit it trim them if need be its not hard
Really? I didn't know there was a difference in the radiators. I have the single core, didn't even know you could get a double core radiator.
Hoses, I believe my lower is stock and the upper is from a 99 Grand am. Or maybe it's the other way around. Been a while since I put it in.
Friday, August 20, 2010 6:10 AM
what cars came with the dual core radiator?
Friday, August 20, 2010 8:47 AM
for a lower im using one from a malibu and a upper from a 99+grand am with the cav radiator. but im swappin to a beretta hoses and cheapo aluminum radiator. had to make the mounts custom tho.
Friday, August 20, 2010 3:09 PM
I use the stock radiator with no problems. I do notice on hot days idleing, it does tend to heat up in the 220-230 range. I didnt even know that there was a double core. My stock hoses fit right up just a little trimming is all thats needed.
3400 SWAP DONE. 187WHP 212TQ (14.2 @100MPH NA) 240WHP 310TQ (N2O)
Friday, August 20, 2010 5:09 PM
eco rad wont work as the ports are in different locations if you use a j body rad OTHER then an eco rad you should have way less work
as for cause that came with them i don't know GM has an option thats added to our cars that gets or some reason for it cause i have seen bas models with the double core and loadeds with the single auto/ 5spd no idea theres no set car that has them i have seen Z24 with both
single is like 1/2 think and a double core is about 1" think
Friday, August 20, 2010 9:48 PM
Hmm.... that's nice and consistent. Typical GM style. If i'd have to guess I'd look for something with a 4spd auto, since supposedly you can tow with that combo. Hard tellin.
Wednesday, August 25, 2010 7:03 AM
I used the stock upper, lower rad hoses and heater hoses from my 96 2.2 and they work fine.
C:\Users\Phillip\Pictures
Thursday, August 26, 2010 3:53 PM
its hard to tell what cars they came in cause my 99 had the thicker rad and i was 5spd and i have seen autos with the small rad and i know the sunfire were working on now that was 00 2200 5spd had the thicker rad
Thursday, August 26, 2010 7:13 PM
Brian Online
I might have to look at mine tomorrow.
Friday, September 10, 2010 11:50 AM
I have a 99 z24, came stock with the thin radiator. I was able to pick up a new 2 core from a local guy that got it off ebay.
Friday, September 10, 2010 2:29 PM
yeah see my 99 Z24 came with the thicker its the most random thing i have seen
Tuesday, September 14, 2010 12:19 AM
I am using a honda dual core "half" radiator...works great so far, will be able to tell better once I get a fan on it and the car gets tuned
Tuesday, September 14, 2010 5:15 PM
why would you use such a small rad when a j body rad is bolt in on a j body
