posted in maintenace too but figured here would be good as well
ok so heres whats going on... 02 LSS sedan ecotec
1. the retained accesory power is screwed up, i figured it was something with the button in the doorway not opening all the way, hauling it open worked but then it got worse, and now after tapping it a bit i knocked the whole assembly out of the hole.. will swapping out the head unit get rid of that?
2. my car seems to buck under WOT coming from lower rpm, had the o2 sensor changed, CEL still reads as the cat is bad (0420 code) nothing else has been done recently
3. my pass side wiper jet doesnt work, lines arent clogged that i can tell
4. on cold starts and until the car has been up to half way up the temp guage for a while when i press the clutch the car will wind down to 500 rpm and labor for a bit before climbing back to 1k does it when stopped and moving, car actually died this morning as a result of it but that hasnt happened in a while
5. lock wont open with the key on drivers side and pass side sometimes wont unlock from the switch but will with the key
thats all i can remember off hand... any help would be great
www.driftnamiperformance.com
