So I have looked everywhere (save contacting Chevy) for the crankcase bolts on the 2.2 ecotec engine. I am building by lower end and would like to get new bolts (Im assuming that these are TTY).
Any Ideas for those of you who have built the ecotec before?
-plaz
Is that a cavalier? ---Why yes.. Yes it is.
GMPartsdirect.com had the best price when I bought mine earlier this year only the inner crank bolts are TTY the outer girdle to block bolts are regular so they won't need replaced.
I used studs... so mine I re use.
I did also, I assume that you are talking about the girdle bolts? I would assume that the dealer may be able to get them?
FYI not all the bolts are the same, the crank (mains) are TTY, the outer bolts are a different size and are regular bolts, they don't have a degree % added after the torque spec. if your not taking out your crank and replacing the main bearings you don't need any of them, but if you have a number of miles and plan on adding more power and stress to the engine then you might as well do it while your in there. ( I figure if your beefing up the bottom end that is in the cards for you.
Damn I just realized that they are about 1/4 of an inch smaller. Now are these the inner (the TTY) or the outer (the ones I can reuse)? My dumb ass did not organize these bolts so I have no clue which bolt is to where.
-plaz
Actually you know I just gonna go a head and replace all of them. Thanks for the advice guys.
-plaz
