Fuel level sensor - Third Generation Forum
Fuel level sensor
Thursday, July 24, 2014 3:48 PM
1998 sunfire new fuel level sensor/pump ,gauge not reading. What is the ohms for 1998 sunfire? When checking with ohm meter on purple and black /white wires on connector which is disconnected from body, I get a reading of 1 ohm with at least quarter tank of gas. Gas gauge reads less than Empty. When first installed, gauge was stuck on quarter tank, then while driving, I hit a pot hole and gauge dropped immediately to less than E. When using test light on Blac/ Whit wire, test light showed Ground on Black/white wire.
Re: Fuel level sensor
Friday, July 25, 2014 4:45 AM
Do you have a digital or analog odometer? 98 J-body cars switched half way through the year, and this is the way to tell.
