Would anyone have some information as to what type of storage chip is being used in the 2003 cav ecotec 2.2 I mite be able to jtag the tosp chip for a full read . Then load the bin into a free tunning software.
I'm going to run the car in a local bomber class dirt track D , so tunning for some more ponies ,
and brake pressure setup to the right and left front brake system maybe possible.
Hp tunner is not an option from what I have read so far .
So tapping into the pcb board is an option if their using a FTA type TOSP chip.
So would anyone have an extra Unit I could experiment with
Thanks wild willie
What makes hptuners not an option? Just curious..
Check this thread out. Maybe he can tell you where he got his p11 controller from?
"In Oldskool we trust"
If those bumpers are still in respectable shape you should dump them to someone who wont trash them before you do. They are getting hard to come by in decent shape. Also, I'm fairly confident the PCM or BCM in any way controls braking pressure. The BCM will activate ABS if you have them, if you don't have ABS the proportioning valve has no power running to it at all.
