is it safe to run nitrous on a 2.2 ecotec with stock internals
you need to confirm that you ecu has an "open loop" mode of operation first....  02's should be safe off the bat, some 03's, but some 03's and all 04-05's don't have open loop, meaning that they will doggedly pursue 15:1 a/f ratio, even with additional injection...  So you can get a cheapie a/f gauge and see if the readout sweeps or not at WOT... if it sweeps, then you will not be safe using nitrous.  If it goes green, then you will be fine.  You can swap to an 02 ECU if necessary, pretty cheap in the junkyards.
DO NOT EVER RUN A DRY NITROUS SYSTEM.  PERIOD.
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
'Nuff said
Yes you can, look into the nitrous forum. Search around the org for a while, you will find a lot of info. Your 1/4 slip is pure BS too.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Why is his slip bs?  I've seen a few stocker ecotecs running 15.2's... he's got an intake and... "greedy" exhaust which I take to mean GReddy... Giving him the benefit of the doubt saying he's got intake/exhaust and he's a decent/light driver, it's highly possible to pull 15.1's on a lightly modified 5spd Ecotec...
could i possibly tell weather or not my ecu is open loopby the pcm or ecu serial numbers? and the hell i dont run those times, ive done a lot of tweaking. plus i have 2 1/2 from the manifold back with no cat and an o2 sim. when i get my pos scanner running again ill post my slip along with some pics of my set up
i have an 04 cav that i ran nitrous on at the track last year, and it melted the 3rd spark plug in the mortor, so is it pretty safe to say that i dont have open loop, it also only ran a 15.1, would it be safe to run an 02 computer on my car and make my track times better
so with an open loop am i going to have to modify my air fuel ratio with a hand held control unit, or will it adjust its self?
when i ran after about mid second gear my check engine light would flash, so im guessing thats why,  i dont think theres any damage, everything still runs ok, but i want to get this fixed, is there any way a dealership can reflash the computer to the 02 specs, also is there any difference between the auto and manual computers, i might have a couple 03s that i can swap with
Tim wrote:Why is his slip bs?  I've seen a few stocker ecotecs running 15.2's... he's got an intake and... "greedy" exhaust which I take to mean GReddy... Giving him the benefit of the doubt saying he's got intake/exhaust and he's a decent/light driver, it's highly possible to pull 15.1's on a lightly modified 5spd Ecotec...
because his 1/8 is 10.7 which is absolutely horrible and in no way can you run a low 15 unless you run sub 10 1/8 miles, unless you have nitrous or something like that and you spray only after the 1/8 mile line
15.574 @ 89 mph stock
DanteMustDie wrote:Tim wrote:Why is his slip bs?  I've seen a few stocker ecotecs running 15.2's... he's got an intake and... "greedy" exhaust which I take to mean GReddy... Giving him the benefit of the doubt saying he's got intake/exhaust and he's a decent/light driver, it's highly possible to pull 15.1's on a lightly modified 5spd Ecotec...
Exactly,  it say you trap 76 mph and 91 in the 1/4. BS dude, maybe if you had nitrous and sprayed after the 1/8 mark haha. Show me a video otherwise I am staying with the
. What "Tweaking" Have you done
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
D@mn Dantemustdie, I quoted you before read your whole post. We think a like, weird.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Scarab (Jersey Jay 1.8T) wrote:you need to confirm that you ecu has an "open loop" mode of operation first....  02's should be safe off the bat, some 03's, but some 03's and all 04-05's don't have open loop, meaning that they will doggedly pursue 15:1 a/f ratio, even with additional injection...  So you can get a cheapie a/f gauge and see if the readout sweeps or not at WOT... if it sweeps, then you will not be safe using nitrous.  If it goes green, then you will be fine.  You can swap to an 02 ECU if necessary, pretty cheap in the junkyards.
Are you 100% on this. I ask cause I got an 03 but with some 04 parts (late year 03), My a/f gauge gets burried at wot in the green and I don't have any problems while under spray. My concern comes in after once I discconected the vss and all my gauges still worked. I was under the impression that on an open loop ecu the gauges go out when thats disconnected (thats what I was told). So if you are 100% on this that would answer my question and I would infact have an open loop ecu.
Check out my cardomain            Team Altered
BIG CHANGES
No, it is not safe to run nitrous on an ecotec
dont do it.
The Only thing Gayer than my cavalier is the purple shade of its nitrous bottle
99redz24 wrote:Brandon G wrote:No, it is not safe to run nitrous on an ecotec
dont do it.
Hehe
 we used a stop watch and speed gun for the 1/8 since they dont have a sensor kit hooked up at the 1/8 mark, so it was kind of a guesstimation on the 1/8 but the 1/4 is right on, i even did another run 2 days ago on free race night when they had the 0-60 and 1/8 sensors hooked up also, and came out with 8.782 for the 1/8 and 15.189 for the 1/4. and now thats cleared up. back to the ACTUAL question?!
will an 02 ecu work in my 03, and will i have to have a plug and play system to adjust for more fuel?
blaine smith wrote:we used a stop watch and speed gun for the 1/8 since they dont have a sensor kit hooked up at the 1/8 mark, so it was kind of a guesstimation on the 1/8 but the 1/4 is right on, i even did another run 2 days ago on free race night when they had the 0-60 and 1/8 sensors hooked up also, and came out with 8.782 for the 1/8 and 15.189 for the 1/4. and now thats cleared up. back to the ACTUAL question?!
It might just be me but an 8.7 does not translate to a 15.1
i missed 4th gear......and now to the actual question
yeah seriously, this isint the racing fourm so lets forget about the racing part of the post, anyway, a buddy of mine just bought the hp tuners software for his 99 vette, and we found out that it can datalog by hooking the obd2 port into my computer, so we tried to run a shot last night with my car. first off its an 04 automatic, so from a stop i started spraying at 3 grand in first, the whole way thought first my air fuel stayed rich lean rich lean like it does an part throttle, after the first shift is stayed ok, but when it was staying rich lean rich lean my knock sensor was going crazy and my car pulled 8 degrees of timing to stop my car from knocking, so bottom line, if you have an 04-05 dont spray, also i have a question, whenever i let off and stopped spraying all my gauge lights came on for a second them went back off, anyone know what thats from and also will a 5 speed computer work in a auto car out of the 02-03 cavs
you missed 4th gear lol, wow excellent driving seeing as how thats like the easiest shift in the gearbox
just get an 02 PCM and be done with it no point in all the guestimation with what you have use what you know will work
Your still lying, 8.7 in the 1/8 is good for a low-mid 13. I don't care if you missed 4th, your nearly stock eco isn't going to run anywhere close to 13's. I guess your mph was 85 in the 1/8 and 110 in the 1/4 right?
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
all "your lying" & "no i'm nots" aside...if i put an 02 ecu on my 04 is it just plug and play? do i have to have anything adjusted in the ecu from the 02 before i put it into my 04? also, looking for one of the questions already asked - will the fuel ratio adjust itself once the new ecu is installed or will be have to adjust it externaly. i'l only planning on running 35-50 shot.
thanks in advance...
donnie
Cant you reset the ecu ? I thought you can come to think of it.
         Winks Online
will a 55 dry shot hurt an early 03 auto ?
