As the topic states does anyone know what size the AN fitting is on the blowdown tube size? I want to run a braided line there instead of a typical blow down tube for a bottle mounting reason. Thanks
Winks Online Click Here
IIRC you HAVE to run the hardened blow down tube if your setup requires one. It is a safety issue and thusly won't be accepted any way but designed if trying to go through tech at a race track.
Just a heads-up.
5K PB: 24:50
10K PB: 54:26
-6 AN / JIC fittings mostly for the street systems.
If you're going to run a SS flex line as a blow tube, at least attach it to a AN -6 bulkhead fitting to the sheet metal you want to pass it  through.
A 1,000 psi fire hose with no one manning the end is pretty scarey. If the nitrous doesn't knock you out, the whipping hose might.
Project S-Bird
Oh belive me this thing isn't going to budge lol I'm like that when it comes to this kind of stuff. Thanks for the info
