Ok here's the deal,My n2o kit has been hooked up for awhile now and I have the WOT switch on the T.B.I have the arming switch in the car and the way I hooked it up(the switch) was obviously power,ground,and 12v acc.The way the 12v acc. was hooked up was inadvertenly done,I ran it to the remote turn on wire for my amp and hooked that to my radio.So the only way you could turn the arming switch on was if the radio was on and if you took the face off or turned the radio off the nitrous could not be used.SO NOW I don't have the radio(sold it) and need to know what other acc. wires I can hook into as I don't have a radio yet.
nevermind,just ran the remote-turn on wire  to the radio power wire
First what year is your cav?
if it is pre 99 you can go right to the radio harness should be green or yellow you will want to test to verify
if newer than 99 this wire is not present as the radio is on the class2 data platform so you would have to go to the ignition switch and grab the heavy gauge pink wire this is true ignition, only on when the key is in run position. remember to fuse your wire.
98 and all you had to do is look at my profile,but I got it figured out,thanks
