flywheel to crank on 1998 cavalier 2.2l 5 speed... any one know the specs?
SEARCH.
Service Information
2002 Chevrolet Cavalier | Unit Repair | Engine | Document ID: 646032
Fastener Tightening Specifications
Application
Specifications
Metric
English
Balance Shaft Cover Nut and Bolt
13 N·m
115 lb in
Balance Shaft Driven Sprocket Bolt (left hand thread)
First Pass
40 N·m
30 lb ft
Final Pass
45 degrees
Balance Shaft to Housing Bolts 8 mm hex
First Pass
10 N·m
89 lb in
Final Pass
40 degrees
Balance Shaft Housing Bolts 10 mm hex
First Pass
15 N·m
11 lb ft
Final Pass
40 degrees
Balance Shaft to Block Bolts 13 mm hex
First Pass
25 N·m
18 lb ft
Final Pass
70 degrees
Balance Shaft to Block Bolts 15 mm hex
53 N·m
39 lb ft
Balance Shaft to Block Bolts 18 mm hex
First Pass
40 N·m
30 lb ft
Final Pass
60 degrees
Camshaft (exhaust) Rear Cover
14 N·m
124 lb in
Camshaft Position Sensor Bolt
10 N·m
89 lb in
Camshaft Sprocket to the Camshaft Bolt
70 N·m
52 lb ft
Connecting Rod Nuts
First Pass
25 N·m
18 lb ft
Final Pass
80 degrees
Coolant Bleeder Valve
Fully Driven, Seated , Not Stripped
Coolant Outlet to Cylinder Head
26 N·m
19 lb ft
Coolant Pump Cover to the Block
26 N·m
19 lb ft
Coolant Pump to the Coolant Pump Cover
14 N·m
124 lb in
Coolant Pump to the Timing Chain Housing
26 N·m
19 lb ft
Crankshaft Balancer to the Crankshaft
First Pass
175 N·m
129 lb ft
Final Pass
90 degrees
Crankshaft Bearing Cap Bolts
First Pass
20 N·m
15 lb ft
Final Pass
90 degrees
Crankshaft Position Sensor to Block
9 N·m
80 lb in
Cylinder Head Bolts
Refer to Procedure
Engine Coolant Air Bleed Pipe
14 N·m
124 lb in
Engine Coolant Air Bleed Pipe Nut
42 N·m
31 lb ft
Engine Coolant Temperature Sensor to the Coolant Outlet
11 N·m
97 lb in
Engine Lift Bracket
96 N·m
68 lb ft
EVAP Canister Purge Valve Solenoid Bracket Bolt
8 N·m
72 lb in
Exhaust Manifold to the Cylinder Head Nuts
42 N·m
31 lb ft
Exhaust Manifold to the Cylinder Head Studs
11 N·m
97 lb in
Exhaust Manifold Upper Heat Shield to the Manifold Bolts
26 N·m
19 lb ft
Flywheel to the Crankshaft
First Pass
30 N·m
22 lb ft
Final Pass
45 degrees
Front Cover to the Timing Chain Housing
12 N·m
106 lb in
Fuel Pipe Bracket to the Camshaft Housing
First Pass
15 N·m
11 lb ft
Final Pass
30 degrees
Fuel Pipe to the Fuel Rail Nut
30 N·m
22 lb ft
Fuel Rail to the Camshaft Housing
26 N·m
19 lb ft
Ignition Coil and Module Assembly to the Camshaft Housings
22 N·m
16 lb ft
Intake Manifold to the Cylinder Head Bolts/Nuts
24 N·m
18 lb ft
Intake Manifold to the Cylinder Head Studs
11 N·m
97 lb in
Knock Sensor
20 N·m
15 lb ft
Oil/Air Separator To Block Bolts
24 N·m
18 lb ft
Oil Dipstick Tube Bolt/Screw
8 N·m
71 lb in
Oil Filter Connector to the Block
29 N·m
21 lb ft
Oil Filter to the Block
3/4 to one complete turn after gasket contact
Oil Pan Bolts
24 N·m
18 lb ft
Oil Pan Bolts, Second Set
12 N·m
106 lb in
Oil Pan Drain Plug
26 N·m
19 lb ft
Oil Pan Studs
26 N·m
19 lb ft
Oil Passage Plug Bolt
30 N·m
22 lb ft
Oil Passage Plugs, Block 1/8x27
10 N·m
89 lb in
Oil Passage Plugs, 3/8x18
30 N·m
22 lb ft
Oil Passage Plugs, 1/4x18
20 N·m
15 lb ft
Oil Pressure Switch
14 N·m
124 lb in
Oil Pump to the Balance Shaft Housing (Long Bolts)
12 N·m
106 lb in
Oil Pump to the Balance Shaft Housing (Short Bolts)
10 N·m
89 lb in
Oxygen Sensor To Exhaust Manifold
42 N·m
31 lb ft
Powersteering Pipe to the Pump Nut
27 N·m
20 lb ft
Powersteering Pump to the Cam Carrier Bolts
26 N·m
19 lb ft
Rear Crankshaft Seal Housing to Block
12 N·m
106 lb in
Spark Plugs to the Cylinder Head
18 N·m
13 lb ft
Starter to the Block Bolt
90 N·m
66 lb ft
Tensioner to Tensioner Bracket Nut
54 N·m
40 lb ft
Throttle Body to the Intake Manifold
10 N·m
89 lb in
Thrust Plate to the Balance Shaft Housing
13 N·m
115 lb in
Timing Chain Housing to the Block Bolts/Studs
29 N·m
21 lb ft
Timing Chain Housing to the Camshaft Housings
26 N·m
19 lb ft
Timing Chain Tensioner to Housing
10 N·m
89 lb in
© 2008 General Motors Corporation. All rights reserved.
Chris
'02 Z-24 Supercharged
13.7 @102.45 MPH  Third Place, 2007 GMSC Bash  SOLD AS OF 01MAR08
Taetsch Z-24 wrote:SEARCH.
Service Information
Application
Specifications
Metric
English
13 N·m
115 lb in
First Pass
40 N·m
30 lb ft
Final Pass
45 degrees
First Pass
10 N·m
89 lb in
Final Pass
40 degrees
First Pass
15 N·m
11 lb ft
Final Pass
40 degrees
First Pass
25 N·m
18 lb ft
Final Pass
70 degrees
53 N·m
39 lb ft
First Pass
40 N·m
30 lb ft
Final Pass
60 degrees
14 N·m
124 lb in
10 N·m
89 lb in
70 N·m
52 lb ft
Connecting Rod Nuts
First Pass
25 N·m
18 lb ft
Final Pass
80 degrees
26 N·m
19 lb ft
26 N·m
19 lb ft
14 N·m
124 lb in
26 N·m
19 lb ft
First Pass
175 N·m
129 lb ft
Final Pass
90 degrees
First Pass
20 N·m
15 lb ft
Final Pass
90 degrees
9 N·m
80 lb in
Cylinder Head Bolts
Refer to Procedure
14 N·m
124 lb in
42 N·m
31 lb ft
11 N·m
97 lb in
Engine Lift Bracket
96 N·m
68 lb ft
8 N·m
72 lb in
42 N·m
31 lb ft
11 N·m
97 lb in
26 N·m
19 lb ft
First Pass
30 N·m
22 lb ft
Final Pass
45 degrees
12 N·m
106 lb in
First Pass
15 N·m
11 lb ft
Final Pass
30 degrees
30 N·m
22 lb ft
26 N·m
19 lb ft
22 N·m
16 lb ft
24 N·m
18 lb ft
11 N·m
97 lb in
Knock Sensor
20 N·m
15 lb ft
24 N·m
18 lb ft
8 N·m
71 lb in
29 N·m
21 lb ft
Oil Pan Bolts
24 N·m
18 lb ft
12 N·m
106 lb in
Oil Pan Drain Plug
26 N·m
19 lb ft
Oil Pan Studs
26 N·m
19 lb ft
30 N·m
22 lb ft
10 N·m
89 lb in
30 N·m
22 lb ft
20 N·m
15 lb ft
Oil Pressure Switch
14 N·m
124 lb in
12 N·m
106 lb in
10 N·m
89 lb in
42 N·m
31 lb ft
27 N·m
20 lb ft
26 N·m
19 lb ft
12 N·m
106 lb in
18 N·m
13 lb ft
90 N·m
66 lb ft
54 N·m
40 lb ft
10 N·m
89 lb in
13 N·m
115 lb in
29 N·m
21 lb ft
26 N·m
19 lb ft
10 N·m
89 lb in
Chris
hate to burst yer bubble boss... he asked aboot teh ohv... seems you posted specs on teh eco... but i dont know, they could be the same.
Edited 1 time(s). Last edited Wednesday, September 24, 2008 9:54 PM
Service Information
Good thing all power plants were used in 02, hence my choice of years.
BUT, if you all don't like it, I will no longer post that kind of stuff up, wouldn't want to piss ya off.
Chris
Service Information
1998 Chevrolet Cavalier | Cavalier, Sunfire (VIN J) Service Manual | Engine | Engine Mechanical - 2.2L | Specifications | Document ID: 254936
Flywheel Bolts
 75 N·m
 55 lb ft
2003 White Cavalier LS Sport Coupe
