What is one of the high end alarm systems, With remote start keyless entry all that stuff??  anyone??
 Viper 791XV
lookin at 400-500 bucks installed i'd say (at least around here)
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
i have the astrostart alarm/remote start 5204 series.. i got 2 remotes, one that is a 2 way led pager ; 2000feet range, keyless entry trunk release.. all that jazz for 700 bucks and oh yes its lowering my car insurance 10-15% when i go and renew it in august
Clifford
Viper98912 wrote:Clifford
same people that make viper..avital, python, sidewinder,valet, hornet....pretty much all the same stuff.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Any of the better model DEI (Viper & Clifford). I have the Viper 791XV. Which ever alarm you decide to get make sure the install is perfect. Without a good install an alarm is worthless. My brain is actually installed from the top of the dash instead of under it. The whole dash has to be taken apart to do anything with it. I also added Battery backup, several piezos, 555L bypass for remote start, and a proximity sensor.
yesh i would def. make sure that u get it professionally installed. im not to keenof viper myself; just based on the fact that a few of my friends got the 791 series and they have all had problems with their alarms..... but thats just my opinion..see if the installer will soder (spelling) the connections just so u wont have a problem with any loose connnections down the line eitherl..
I like the Compustar alarms...
<a href="http://www.lenkorules.com/"><img src="http://s93165229.onlinehome.us/images/zm/sig/LRDCsig3.jpg"></a>
791xvr hands down. I am a MECP certified installer and solder all of my connections. I have never had any problems what so ever. I have a 98 z-24 and the $2000 worth of equipment I have in the trunk is well worth the $500. And also being how noby cares anymore about car alarms going off this on e will page you so you know.
Alpine 9855 deck                                 $500
Alpine Mrd-m1000 amp                     $950
2 Treo 15's                                           $500
Rockford digital cap                            $200
6 1/2 alpine Type R componets        $269
Typr R 6x 9's                                          $160
Alpine 75x4 4ch amp                            $ 500
        $3000 worth of equipment protected by the best name in the buisness                           PRICELESS
there are many alarms that will page u, and even show u what sensor is being violated. so does my astrostart and it even vibrates as well.. i guess it all depends on who installs the system for you
Viper 791xv.  I have it and it has worked well.
Best one?  Not really sure.
I have the Matrix RS2 and enjoy it thoroughly, I have had it for almost 3 years now with absolutely 0 problems with it.  However, I would really enjoy one of those pagers that notifies me when the alarm is going off......
just an idea for some of you, i had my car broken to recently.  I bought my viper alarm/start 1 month before the pagers came out.
Anyways, the bastards just open the fuse box under the hood and pulled fuses until my sirens stopped.
So, next time id put a cable tie or a metal strap around my fuse box so it cant be opened.
Just 1 more lil thing to slow down the pricks.
new pioneer avh-p7500dvd = 1600 CDN
The Viper 791XV with the first gen style remotes(silver in color) suffered from a couple of design flaws.  The first was two separate circuit boards that were surface mounted-these surface solder connections have a tendency to break from your typical usage(throwing your keys on the table, dropping the remote, etc...).  The second problem was with the vibration feature.  The motor assembly was pressure fitted into a mounting clip, which would shift to the side after a while of vibration and catch the underside of the transmitter coil, causing the coil leads to break.  If you do go with the 791XV, make sure it has the second gen remote(blue).  Also, you may consider the Audiovox APS-996A, which has all of the features of the 791XV and a better operating range, as well as more outputs if you decide you want your security system to do a lot more things(window automation, door pop solenoids, remote neon lighting, etc...)
I also have the very first version of 790 like wringer I like it cause DEI made a trackin
gps add-on so u can know where your ride is at all time Almost like on-star &  ADT  for the ride
