well i woudlnt mind hooking up a LED or several of them that lightup in a stream and move back and forth and hook it up to my mirror...
YES I KNOW...SAVE UP AND BUY A REAL ALARM....dont bother me with that at the moment
anyways...how would i go up wiring this up? What should i hook it up to? (Not my ciggarette lighter. Its in a dumb spot on 2001 Sunfire GTs). DO i need to splice wires? I only want this thing going on when the car is off and the factory alarm is set.
The "scanners" (the lights that stream and move back and forth) usually have three wires.
- Ground: find some metal
- Power: Cig Lighter or Ignition (cig lighter is the easiest usually, and these things take no power at all so there is no worry about overloading the circuit)
- Ignition: by the key, this tells it to turn off when your car is on
Jay
One huge aluminum wing - $200
More vinyl graphics than your ride can handle - $150
Decals for products you don’t even have - $10
500lbs of Car Audio equipment in the trunk - $1500
Getting slaughtered by a KIA - Priceless
so how would i actually go about wiring them up then?
do i gotta tkae my steering column off? all that crap...
i know nuthing about sunfire electronics
derek1986 wrote:so how would i actually go about wiring them up then?
You can't wire anything without taking something off. The wires are hidden behind all the plastic, how else are you going to get to an ignition wire for example?
derek1986 wrote:i know nuthing about sunfire electronics
Well... you have to start somewhere. But don't mess it up! You could create a lot of problems if you do crappy wiring.
Jay
