Ok everyone i have built a custom fiberglass box that takes the place of my back seat.  I covered it in foam and then black vinyl.  After i covered it i put my 12" l7 in there and then tested it out and i blew up the back of the box.  Does anyone have suggestions on my next box, how think should the fleece be and how many layers.
go and check out
http://www.gadomestics.com/
Just so I know, you only used fleece? Use several layers of chop matt and cloth. Fleece and resin is brittle and should be used only as a form.
If you can't stand on the enclosure without it buckling, keep building it up.
I saw pics of an enclosure for an F-Body that was used as a jackstand for a Corsica to illustrate just how strong it was, so it is possible.
Slot Ported Box Design Calculator
post them on a site like photobucket.com, and then link the images from there (it's a button on the top of the reply text box that shows an arrow pointing to the top of a picture with a mountain in it)
so it just blew out that little hole??
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
no the back of the box behind the speaker exploded, the only holding it togther is the vinyl.
go and check out
