I'm doing a install on my cavilier this weekend. I need to run three sets of rca's to the trunk. What length rca's will I need ? Also where are the good spots to runn the power wire throught the fire wall ?
BTW it's a 2002 Coupe.
Thanks guys.
terry walker wrote:I'm doing a install on my cavilier this weekend. I need to run three sets of rca's to the trunk. What length rca's will I need ? Also where are the good spots to runn the power wire throught the fire wall ?
Thanks guys.
The power wire goes throught the grommet on the driverside. Cant miss it, its about the size of your fist.
The rca's are 15 ft i believe, but last time i ran mine were over a year ago.
Thanks, I havn't taken it apart yet, so instead of searching for the existing gromount I figured someone on here would know where they where. Also Thanks on the info for the rca's I just didn't want to have an extra ten feet of wire to hide. I thought maybe I could get away with 9ft'ers but I don't wanna come up short. I think I'm going to run them straight down the middle of the car.
If anyone knows if I can get 9fter's to work, lmk.
Thanks.
2002 Cav.
2.2
5 speed yellow
Yea it's stock,
Yea I know Stock sux.
I couldn't get 12 footers to the trunk of my cavy so i dont think you'll have much luck with nine.
Don't dig on the newb's sig!!!
I know that my 18fters are too long - I would think 15 feet would be enough to get you to the back of the trunk and still allow you to hide the wire behind all body panels.
The 50-50-90 rule: Anytime you have a 50-50 chance of getting something right, there's a 90% probability you'll get it wrong.
Unholysavage wrote:I know that my 18fters are too long - I would think 15 feet would be enough to get you to the back of the trunk and still allow you to hide the wire behind all body panels.
Very cool, I'll go with the 15ft'ers I hope they work out well.
Thanks guys.
2002 Cav.
2.2
5 speed yellow
Yea it's stock,
15 ft was a little bit too long, but you should be able to make it.
i have 16.5 ft RCAs i'll sell you super cheaper. Monster Cables so they are good quality...pm me if your interested
I used 15's as well. Any shorter is difficult to work with, any longer is overkill unless you're going to mount the EQ or amps on your trunk lid
I got 9ft rca's, but my brain to my HU is under my passenger seat, and the amps are in the back seat.
anywhere from 15-18should be fine.
My Myspace Page
I used a 10 footer (3 meters). It goes from the HU, pulled just about tight, straight down the middle of the car, which is a complete bitch to do, and my amp in on the driver's side of the trunk. I have about 6" extra cable. So it's close, but I did it. Depends on where you're going to put the amp I guess.
