Sony CDX-F7710
Audiobahn A4004T 40x4 RMS
Infinity Reference 6.5" 2 way
Infinity Refenence 6x9" 3 way
Infinity Reference 1" tweeters ran off the headunit in the door panel
Audiobahn A8000T 800RMS @ 2ohm
Alpine SWR-1242D run at 2 ohm
Ported box Built by alpine specs
Should be a clean sounding audio system I'm hoping for. I'm also using a Rockford 1 farad capacitor. I already have the head unit, door speakers, and sub. My girl wants to get me the mono amp as a late x-mas gift. I plan to have it all done by then to ensure that I have all the money for it.
Is this goin to be a good lower budget setup for some decent sq? Thats all I'm lookin for is a lil bit better sound out of my ride. I listed to alot of stuff. Rock, Classic rock, Rap, Country. I like my music and am lookin for something to sound good. I mean right now it's alright but am lookin for better.
forget the sony if your budget wise look into a lower end alpine or a pioneer i swear by them
I am keepin this stuff it's the rest that I need otherwise I should be good right?
yeah it should be fine than
Also with the ported box alpine listed these dimensions
18"x13.5"x16.5" External dimensions
port hole 12"x1.25"
will this box be ok and help my sub to have some decent bass.
The sony is fine, they sound just fine as long as you don't use the internal amp and just use the RCA outs
Causa latet vis est notissima
DIY Clear 03+ Headlights
Sony sux, also I wouldn't use the reference line from infinity. Most of the other infinity stuff is great!
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Sony is not that bad ( long as its just the HU). I have no complaints with the HU but Its the amps and subs to stay away from unless ur just looking for just a lil bump and not trying to blow ur eardrums out. IMO
<a href="http://www.userbars.us" target="_blank" title="1000's of FREE Userbars at Userbars.us"><img src="http://www.userbars.us/./data/media/10/pontiac.gif" border="0"/></a>
The01Cav wrote:Also with the ported box alpine listed these dimensions
port hole 12"x1.25"
How long is the port?
I think the box is small for a ported box. You're looking at 1.6ft^3 TOTAL.....without subtracting port and sub displacement. You'll probably be close to 1 cu. ft. after subtracting those. For my single SE10 I started with 1.8 ft^3 before sub and port...after it came out to 1.4 ft^3. I know it's a different sub but I'd still go bigger. Sometimes spec boxes aren't the best.
I would probably go with a 1.75-2" wide port or so just to get more port area....and of course a little bigger box...probably around 2 ft^3 or a little bigger without subtracting for displacements tuned to around the lower-mid 30's.
For SQ try to stay in the low 30's for tuning. 30-33 is good.
the vent lenght is 22.75" this is what alpine has in there book that comes with the type R could you give me some dimensions for it otherwise? I thought about usin there dimensions as internal dimensions as apposed to external
Also how exactly do I go about this vent length what exactly is it?
It determines the tuning of the box. Typically longer means lower.
Right now I can't even determine the tuning of that box because my port calc. wont let me enter a port with a width height ration more than 1:8. Right now that port is at 1:9.6. A 2"x12" vent would be a 1:6 ratio. The ratio is usually used to keep port noise down.
This box building site may be usefull to you. Just enter the sub info along with 2 sides lenghts you have figured for your box (measure and see how much room you have...or want to take up. The program will automatically figure the 3rd. based on the vol. of the box you enter), and enter what freq you want the box tuned at. 30-33 is usually good for a SQ/SQL mix. It will pop up a window with the box drawn out. it will even print out a cut list for all the pieces you need to cut. Very helpfull site.
http://www.accelerator-pedal.com/ported-box.asp
oh ok I was lookin at building the box tonight if possible how would it be with the outer dimensions used as inner?
I would go with components instead of the coaxials and the extra set of tweeters in the front.
09 HHR LS, Wife's Car
05 Cavalier, Clarion DXZ375MP, Autotek MM8000.5 & 13Kv.2, wife's old car, updates coming soon
